    look on fleabay for "slotted opto", returns half a dozen options... just the device.. will need mounting on a small circuit board with a couple of resistors, and you'll have to rig up some sort of vane on the spindle to interrupt once per rev...
    Alternatively, and more easily, if you are set on the ebay display, use a 74HC390 divider chip to give a 'divide by 50' with only 1 chip and 10 solder joints!
    Ok that sounds good but this is uncharted ground for me, the 74hc390 seems like the way to go and i will get a new slotted sensor just to be on the safe side as i dont know if the existing one is ok, you make the circuit sound so simple ill just trust your judgement over mine:confused:
    Rick
  2. Quote Originally Posted by Ricardoco View Post
    Rick
    Rick,
    Circuit attached...
    I'm guessing the opto will need to be powered so I have shown likely values (330R/4k7) for the resistors needed to energise the LED and bias the receiver. If you knew what type it was I could give you better values but these should do.
Name:	divide by 50.gif
    Rick,
    Circuit attached...
    Thanks Irving, I went for the H22A1 type sensor if thats any help. I couldnt see Attachment there anywhere ...derrr lol
  1. The Boxford 260VMC as you probably never seen it before!
    By rnr107 in forum Boxford Vertical Mills
    Last Post: 28-04-2021, 07:57 AM
  2. Boxford 260 VMC
    By shoeswith in forum Boxford Vertical Mills
    Last Post: 10-04-2017, 06:20 PM
  3. boxford vmc 300
    By bigred5765 in forum Boxford Vertical Mills
    Last Post: 22-04-2014, 04:22 PM
  4. Boxford mt2
    By Hellfire in forum Boxford Lathes
    Last Post: 03-08-2012, 08:46 AM
  5. Boxford 160 TCL
    By Brinner in forum Boxford Lathes
    Last Post: 31-03-2012, 09:11 PM
