  1. #10
    Q1 Are these illuminated switches? If not, consider using illuminated ones inatead of LED repeaters, saves real estate and assembly effort and looks neater
    Mainly because ive got the LED's and the nice chrome holders on the shelf, and ive also got the switches, (shown in previos post) and to be honest ive seen and used many broken illuminated switches but never the solid top ones.
    Q2 How are these going to drive the mill when Mach3 is switched off?
    At first most of the switches will just address MACH, but when thats up and running, I will use this (already purchased.)
    Q3 As it stands I reckon you need 11 inputs to mach 3, you have 10 on 2 parallel ports...
    Not all the buttons will be connected to MACH, IE none of the spindle motor speed controls and most of the others are power switches anyhow.
    Q4 Whats 'Feed' for?...
    If i am to have successful manual control i will need to have a feed rate control
    Q5 If the small round circles are LEDs how will they be driven for the mains circuits e.g. computer and monitor power (and do you really need those anyway?)
    I have these on the shelf too :)
    I am as always open to suggestions from people who have experience using a mill both manualy and by CNC so if you see anything you think i have missed or messed up then pipe up because I will just as likely forget..
    Having looked at the panel the only wsitches that will address MACH are 2*X, 2*Y, 2*Z, 2*A & E-Stop. that makes 9 I think lol
    Rick
  1. The Boxford 260VMC as you probably never seen it before!
    By rnr107 in forum Boxford Vertical Mills
    Last Post: 28-04-2021, 07:57 AM
  2. Boxford 260 VMC
    By shoeswith in forum Boxford Vertical Mills
    Last Post: 10-04-2017, 06:20 PM
  3. boxford vmc 300
    By bigred5765 in forum Boxford Vertical Mills
    Last Post: 22-04-2014, 04:22 PM
  4. Boxford mt2
    By Hellfire in forum Boxford Lathes
    Last Post: 03-08-2012, 08:46 AM
  5. Boxford 160 TCL
    By Brinner in forum Boxford Lathes
    Last Post: 31-03-2012, 09:11 PM
