Thread: The illusive Boxford 260vmc
19-08-2010 #241
Im fast leaning in that direction, i may just wait and buy the tachulator, its off the shelf, programmable, it comes with the sensor, and it has good reviews, I did'nt want to go down the build your own route as ive done all this PCB DIY before it drives me nuts but at least i had a go. the thing is i dont enough hours in the day as it is. Having built the circuit got the display and the sensor now comes all the tinering about, it really would have been quicker and less hastle to just buy one lol. but i really do believe in buying within the UK if possible..
20-08-2010 #242
On a side note i2i i think you may have converted one of these machines before, Do you know where i start to calibrate (if that is the term) the machine with mach EG so 10mm in mach is 10mm on the axis..
20-08-2010 #243
It may be different for you as you've got different stepper drivers in your machine. But the jist of it is, set it to mm, set the step and direction pins for each axis and enable the axis, got to motor tuning and set the steps to 200, the velocity to 1500, and the acceleration to 50, for x y and z, making sure you save tha axis settings each time. You'll need to set the step pulse length to 5ms, and you'll only need to do that once.
20-08-2010 #244
I did all that at the begining, Sorry I made a hash of that question... What i was trying to say is, what do i need to do to make the amount of travel in say the x axis 10mm on the bed and 10mm in mach, so if i tell mach to move the x axis 10mm it moves 10mm as opposed to say 12mm for example? .... there, clear as mud lolLast edited by Ricardoco; 20-08-2010 at 06:01 PM.
20-08-2010 #245
ok what are the steps set at in motor tuning, and what exactly do you get if you move it 10mm by mach
20-08-2010 #246
LOL im not getting this am i lol Ok I thought i had to set the screw spec so mach knew how far 1 rev of the stepper would cause the bed to travel, I wanted to know how i find this information to put into mach lol, sorry im between shifts at the moment so ive had a night shift and no sleep till tonight so I can reset my body clock while im off work.
RickAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
20-08-2010 #247
there is a way to do it automatically in mach, you enter the pitch and steps and gearing and it works it out for you, but it should be 200 steps. Try it on 200 steps, it's easy to change when you know how much it's out.
20-08-2010 #248
go to the settings page, and it's in the lower left corner
"set steps per unit
20-08-2010 #249
20-08-2010 #250
i'm sure i set the last one at 200 steps in motor tuning.
The Boxford 260VMC as you probably never seen it before!
By rnr107 in forum Boxford Vertical MillsReplies: 36Last Post: 28-04-2021, 07:57 AM -
Boxford 260 VMC
By shoeswith in forum Boxford Vertical MillsReplies: 3Last Post: 10-04-2017, 06:20 PM -
boxford vmc 300
By bigred5765 in forum Boxford Vertical MillsReplies: 0Last Post: 22-04-2014, 04:22 PM -
Boxford mt2
By Hellfire in forum Boxford LathesReplies: 6Last Post: 03-08-2012, 08:46 AM -
Boxford 160 TCL
By Brinner in forum Boxford LathesReplies: 1Last Post: 31-03-2012, 09:11 PM
