Thread: The illusive Boxford 260vmc
21-08-2010 #281
I wasnt sure what to set the speed to the spindle or the motor, it looks like 3-1 gearing on the belt or something like that. So i just set it to 2000..
Besides which how would i tell what speed it was doing :lol:Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
21-08-2010 #282
there is a cermet preset on the cncdoctor analogue board, which normally needs to be set around max.
21-08-2010 #283
here's the tacho.
http://cgi.ebay.co.uk/Digital-Laser-...t_Equipment_ET
21-08-2010 #284
you may find it cheaper, or cheaper postage if you search.
I have one and they work perfectly.
21-08-2010 #285Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
21-08-2010 #286
Ok found it, so I have steppers all done working calibrated, Spindle working, and axis direction sorted..Ive been playing with this Pokeys55 board, Now thats a cool piece of kit, all ive got to do is get that front control panel drilled and sorted and im away :)....Mind you there is a few little bits to do not to mention the cosmetic side and the flood coolant system i intend to fit :)
21-08-2010 #287
sounds like you're almost there, have you done the home switches yet, and does it home correctly. If so then it's soft limits next.
21-08-2010 #288
I had done it but it was untidy so as i speak im tidying it up, should only take 15 mins or so then as you say its soft limits, I believe that you can set things up so that the axis hit limits and back off to home...
21-08-2010 #289
I'm terrible at spelling...but loosing an volocity ...
Pity you didn't have a webcam setup,Rick?
21-08-2010 #290
The Boxford 260VMC as you probably never seen it before!
By rnr107 in forum Boxford Vertical MillsReplies: 36Last Post: 28-04-2021, 07:57 AM -
Boxford 260 VMC
By shoeswith in forum Boxford Vertical MillsReplies: 3Last Post: 10-04-2017, 06:20 PM -
boxford vmc 300
By bigred5765 in forum Boxford Vertical MillsReplies: 0Last Post: 22-04-2014, 04:22 PM -
Boxford mt2
By Hellfire in forum Boxford LathesReplies: 6Last Post: 03-08-2012, 08:46 AM -
Boxford 160 TCL
By Brinner in forum Boxford LathesReplies: 1Last Post: 31-03-2012, 09:11 PM
, as an offset i can hold my breath for over two minuits!!:rofl:
