Page 34 of 35 FirstFirst ... 2432333435 LastLast
  1. #331
    i2i's Avatar
    I had a feeling that you hadn't got the lights working as there was no news of a Kent substation failing.
    I actually found an old 260 vmc front panel, in one of my bits boxes.
    Switches with lights, are you drooling yet
  2. #332
    :surprised:----:cry: erm.....:nope:or whats it like then? LOL
  3. #333
    Quote Originally Posted by i2i View Post
    seems to be working well, it'll not be the same without the lights.
    Sorry to interupt, but what lights ?
    P.S or is it some sort of joke between (You) i2i and Ricardoco...../
  4. #334
    i2i's Avatar
    i'll take a pic tomorrow and post it up
  5. #335
    i2i's Avatar
    I've just looked back through this thread, and it's the same as your original front panel.
  6. #336
    i2i's Avatar
    Quote Originally Posted by Vitality View Post
    Hi Vitality, have a read through the thread, it'll explain it better.
  7. #337
    I'd like to know how you're holding the aluminium plate down in that video? Some sort of adhesive?
  8. #338
    Ahh yes well spotted:naughty:, the aluminium plate has a 10mm edge profile but steps out to 18mm thick 50-100mm in from the edge, the mdf has a machined socket to accept the 8mm step and yes you are correct there is double sided sticky tape to hold it firmly in place together with a tight fit, this allows me to repeat the process without having to set things up each time.( i have several pieces of stock the same size and profile) I just slot the new material in the socket push down firmly and hit the cycle start button in mach3
  9. #339
    Ok, so to begin with ive jotted an idea down in paint, there are no dimentions at the moment as i will have to base any measurements on the toolholder and the type of collets, im hoping you will all help me design this little addition with input such as bearing type tool holder type and collet type (not too expensive) the drawing is just a basic concept..
    So chirp in if you have any input :idea:
    Rick
  10. #340
    Ok after a few PM's :whistling:Ive taken on some suggestions to the design like the addition of oil seals in front of the taper bearings and an oil gallery possibly for pumped cooling, and the addition of R8 collet dimentions, so any more input would be very usefull IE bearing type, coolant type, tool holder size and the such...:question:
  1. The Boxford 260VMC as you probably never seen it before!
    By rnr107 in forum Boxford Vertical Mills
    Last Post: 28-04-2021, 07:57 AM
  2. Boxford 260 VMC
    By shoeswith in forum Boxford Vertical Mills
    Last Post: 10-04-2017, 06:20 PM
  3. boxford vmc 300
    By bigred5765 in forum Boxford Vertical Mills
    Last Post: 22-04-2014, 04:22 PM
  4. Boxford mt2
    By Hellfire in forum Boxford Lathes
    Last Post: 03-08-2012, 08:46 AM
  5. Boxford 160 TCL
    By Brinner in forum Boxford Lathes
    Last Post: 31-03-2012, 09:11 PM
