Thread: He's added a fourth axis
01-08-2010 #32Keeping it simple now,decided to use the chuck and spindleon a home made lathe.George,
What are you thinking of making with your new machine and 4th axis?
Got the motor(2500rpm),got the pullys...one 50mm V type for motor shaft,one 4" for the spindle...will worry about gearing when its up and running? the speed contoller is a simple one for now ie it came off a defunctn router.
The bed will be 25x25x3mm box section,Ifigured its not worth making it big ie 600x250x250mm should do it.
Ordering the toolpost and tail stock from www.littlemachineshop.com
Why is it that you can get anything and everything under the sun from the states and you try here in the UK and its like looking for a needle in a haystack...really pi**es me off trying to buy stuff over here.
DeskProto 3D cam software, forum support added!
By Lee Roberts in forum DeskProtoReplies: 0Last Post: 27-01-2014, 03:21 PM -
Fourth Axis... Thoughts?
By kingcreaky in forum Linear & Rotary MotionReplies: 3Last Post: 08-07-2013, 08:24 PM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
