Thread: Need to drill a spanner shaft
31-07-2010 #5
This is what I use when I come across a tough job.
http://www.leofixings.com/fixings-pr...ts-10-132.html
This is also the place I get most of my drills, nuts, bolts, washers, in fact lots of things. I doubt if you will find cheaper for such quality, and yes, you can get a thousand screws for a couple of squid. Much cheaper than B&Q.
Bogs
taperlock fit on a shaft - h5 / h6 ?
By dsc in forum Machine DiscussionReplies: 3Last Post: 03-09-2013, 09:09 PM -
6mm shaft to 6.35mm hole?
By JuKu in forum Metalwork DiscussionReplies: 3Last Post: 15-12-2012, 02:29 PM -
shaft - grinding part joint
By dsc in forum Linear & Rotary MotionReplies: 9Last Post: 21-11-2012, 09:31 AM -
Stepper shaft couplings - can you ID these?
By HankMcSpank in forum Stepper & Servo MotorsReplies: 17Last Post: 15-04-2012, 03:46 PM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM
