Thread: My spindle design
Thanks Barry.
Theres some good links that i didn't find, Thats why I like this forum...
I did see the Henriksplace one and In all reality, design wise, thats what I will end up with, minus the hardening and grinding bit.
to be honest I hadn't thought about that, do you think it will that much of an issue? after all it i will be fairly small diameter stuff machined in one operation( if I can sus it out)What are you thinking of for balancing? Do you think building it all up and sending it off for balancing would be an option? Or do you think offsite individual part balancing, followed by offsite assembly balancing would be required?
Probably not but I have plenty of AL stock and cheap bearings to practice on. and I'm willing to learn, if my lathe will let me.Can you machine it to hold the tight run out a spindle often has?
Probably another post in it self but what is the max speed you can get before its to noisy? Have you geared it?I went for the 3 phase and VFD option for the reasons you mention, plus nice and quiet!
Yeah I have concidered that as apparently they have a double A/C bearing in the nose but having looked at this siteOn second thoughts, maybe start with a die grinder as 2e0poz suggested in another post . . .
http://www.cncathome.com/spindles.html
he reckons that they are are just up rated routers so the noise is a problem, but i would like to know if anyone has had any success with them?Last edited by Ross77; 02-08-2010 at 12:44 AM.
02-08-2010 #2
Whats wrong with an induction motor being used?
This one I have is heavy and I reckon its the motors body thats the bulk of the weight?
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
DIY spindle design
By Jeremy in forum Brushless Spindles & MotorsReplies: 44Last Post: 11-09-2015, 12:04 AM -
Design Help Pt2 Required for CNC design/Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 38Last Post: 21-07-2014, 02:05 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
