Thread: My spindle design
03-08-2010 #1I know. how about this??Lighten up,Ross...I was only jesting.
Thanks Steve....... I Wonder if I will ever get this working..Sorry, this is the blind leading the blind unless some has actually done this . .
Not the dreaded vibration stuff again :naughty: there is a version in my mind that inverts the motor so it is parallel to the spindle and mounted the opposite side of the y axis gantry but running the opposite way to the spindle to cancel out the inertia (not sure of the terminology)........I asked about balance because the spindle I bought had balance holes in the collet nut. It's another step towards a more refined and accurate machine.
yeah I'm under no illusion that I can make a super accurate precision spindle that can run 24/7, but I would like to have a fighting chance of making a decent home use one.Maybe you're beating yourself up a bit there with what you might achieve,
I've been looking at the A/C bearings and there are so many to choose from with different angles and precision ratings, I can get a budget one for around £12 but the proper matched pairs can be around £100 or more. I just need to work out if using good bearings will average out my machining skills or if they are a waste of money at the moment.
I can see my self just getting the cheap ones and a few deep groove ones and then just trial and error... if the run out is acceptable and it doesn't flex or chatter when cutting then job done
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
DIY spindle design
By Jeremy in forum Brushless Spindles & MotorsReplies: 44Last Post: 11-09-2015, 12:04 AM -
Design Help Pt2 Required for CNC design/Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 38Last Post: 21-07-2014, 02:05 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
