Thread: Z axis motor 'lifting'..
The Z motor must have been moving a bit though for a cut program of that length in time...I can't imagine that it was at the same depth for 2.5 hrs?
But yes motors do get hot when stationary as current is still passing through them to keep their position locked & stationary.
As for the Z axis being off....there could be lots of reasons - something in the code that you missed, something mechanical in the Z drive train that could cause it to bind in one direction, interference in cabling could cause dropped steps...& probably many other things as well.
02-08-2010 #2
Hi Crafty..
Yep, 2 hours of flat cutting before the z axis has to start moving (0.01mm cuts).. Bit extreme I know, but I figured I would get to see any of the problems by cutting this part this way.. Will fit a heat sink and fan later, then do some proper testing to check it out properly..
Steve..
Help with 3 axis CNC motor and drives
By domagoj55 in forum General ElectronicsReplies: 7Last Post: 04-03-2013, 12:51 PM -
THC lifting off sheet?
By lockyg in forum Machine DiscussionReplies: 2Last Post: 06-12-2012, 04:56 PM -
NEW MEMBER: Okuma Z axis motor
By hidro in forum New Member IntroductionsReplies: 0Last Post: 21-03-2011, 02:15 PM -
By hidro in forum New Member IntroductionsReplies: 0Last Post: 21-03-2011, 08:52 AM -
High Torque Motor Z Axis
By Lee Roberts in forum Stepper & Servo MotorsReplies: 5Last Post: 17-05-2009, 10:08 PM
