Page 14 of 22 FirstFirst ... 41213141516 ... LastLast
  1. #131
    Mark list all your inputs and how you are using currently using them.
    Phil
  2. #132
    off the top of my head..... mach setup is saying iv 4 inputs i can use... that would have been fine if i didnt have the slaved x axis
    i need one for E-stop two for Z home one for Y home and one for Z home
    i know there are other exotic ways of running switches parrallel/series etc but i woul like my "home" away from the extream edeges of my machine so i can easily keep an eye on lost steps
    im assuming another port will give me another 9 inputs ???? cant remember,,,, my brain is melting :)
  3. #133
    Not true guys? if you want compatibility out of a cheap card they say go for one using 'NetMos' driver chips onboard. I bought a second card that cost less than a tenner and it works with EMC2 fine and others have reported this chip to work well with Mach3 also. I used the details here http://wiki.linuxcnc.org/cgi-bin/emcinfo.pl?NetMos to help me decide which card to buy and Linux picked it up no problem. You have to specify the address in the config file and it was this guy off Ebay i got the card i used from http://myworld.ebay.co.uk/fullspeedit.
  4. #134
    Doh just realised i was replying to the previous page on this thread. Oh well
  5. #135
    http://cgi.ebay.co.uk/PCI-IEEE-1284-...item43a1c7cfa1
    to late now, its orderd
    ill find out soon enough :)
    i might wire up without a Z home for now and add it when i can
  6. #136
    f750's Avatar
    Lives in herne bay, United Kingdom. Last Activity: 21-11-2022 Has been a member for 9-10 years. Has a total post count of 13. Received thanks 1 times, giving thanks to others 0 times.
    Hi Mark just read ball the thread,very interesting I use a 650kv outrunnnermotor on a mill with a 80 amp speed controller, servo tester and a 15volt psu supplly. I have run it on mach3 to cut some small bearing pockets taking a 1mm cut with a 6mm cutter Ihave not had any problems with heat build up. I have fitted a fan on top of the speed controller bolted to the main frame of the mill.
    Tony
  7. #137
    Hi Mark just read all the thread
    hahaha!!! that must have took some doing :)
    i dont have any heat trouble with the larger two motors, its the tiny 4000kv spindle thats giving the bearings im using a hard time m250cnc(phil) thinks it may help if i run them in bit by bit not alowing them to over heat or trying lighter grease, ill give those a try when i find the time
    thank god somone has a rc brushless motor spindle working for them, loads of people seem to have a go at building them but iv had no reports of any useful results untill yours, are you running it 1:1 or are you on pullys and belts??
  8. #138
    f750's Avatar
    Hi Mark I use a Arceuro ER16 which is 1:1, the motor is actualy a 800kv have loaded a photo
    Tony
  9. #139
    Splendid!!! 1000w (ish) ??
    i might need to fit a fan to my esc, it gets to hot to touch now and again
    are you not finding the 800kv a bit quick to cut aluminium?
  10. #140
    f750's Avatar
    I use good quality aluminium and spray a small amount of WD40 to lubricate.
  1. laser cutting ally plate
    By i2i in forum Tool & Tooling Technology
    Last Post: 21-02-2013, 08:47 AM
  2. FOR SALE: 45 by 90 ally profile
    By johngoodrich in forum Items For Sale
    Last Post: 13-09-2011, 06:45 PM
  3. RFQ: anyone wanna quote me to cut some ally?! and....
    By robmurf in forum Projects, Jobs & Requests
    Last Post: 01-09-2010, 01:16 PM
  4. NEW MEMBER: anyone wanna quote me to cut some ally?! and....
    By robmurf in forum New Member Introductions
    Last Post: 01-09-2010, 10:31 AM
  5. Model Engineering Exhibition @ Ally Pally
    Last Post: 18-01-2009, 10:15 AM
