Thread: Fingers crossed it'll cut ally
04-08-2010 #11
Hi Mark,
Those brushless motors look like the type I use in my model aircraft. I was wondering how you are controlling them, and what power source you are going to use. Looking at your stats for the big motor:
2800rpm for 12v is a 233Kv motor. This will obviously give you 8633rpm at 37v no load.
1700W is achieved at 45A for 37v. Do you have a 37v supply, and more to the point, can it give out 45A at the same time? The 12v 60A supply we have at work is the size of a suitcase, and probably cost us a bit, so I'm interested in the bench supply you have in mind. If you have simply read the motor spec, then you might like to know that on aircraft, when run from Lipo cells (37v) these motors run at about 45A on average (depending upon prop and throttle), and last for 8 - 9 minutes before a recharge is required. If your bench supply can't give this kind of current, then your actual power will be down (plus not so efficient), and you may have to back off on the ali cuts. But then maybe you have a cunning plan for all this . . .
I assume you are using a speed controller to run the brushless from. What amp rating are you running on that, and are you using a servo simulator to control the speed on a dial?
If you can get this all to work, then you're right about the noise, very quiet. I did consider this route myself, but the above put me off. Keen to see more . . .
laser cutting ally plate
By i2i in forum Tool & Tooling TechnologyReplies: 12Last Post: 21-02-2013, 08:47 AM -
FOR SALE: 45 by 90 ally profile
By johngoodrich in forum Items For SaleReplies: 5Last Post: 13-09-2011, 06:45 PM -
RFQ: anyone wanna quote me to cut some ally?! and....
By robmurf in forum Projects, Jobs & RequestsReplies: 2Last Post: 01-09-2010, 01:16 PM -
NEW MEMBER: anyone wanna quote me to cut some ally?! and....
By robmurf in forum New Member IntroductionsReplies: 2Last Post: 01-09-2010, 10:31 AM -
Model Engineering Exhibition @ Ally Pally
By irving2008 in forum General DiscussionReplies: 6Last Post: 18-01-2009, 10:15 AM
