Thread: Fingers crossed it'll cut ally
11-01-2011 #11iv considered it for long runs, might be a pain to get the holes routed to each o-ring if its a complex patternYou could stick a sheet of whatever plastic you're using down to the bed and mill slots/holes for the air
the problem with mixing diffrent size o-rings is the diffrent surface arias would compress the o-rings diffrent amounts
im going to try using one syringe and fix one of the one way valves as an exsaust so you could pull the initial vacuum the pad valves will hold the vacuum ill press the syringe home and the air iv removed from the pads will be routed through the exsaust one way valve ?????? if you can get your head around that :)With a sufficiently big syringe how many pads do you think could be served? Or are you sucking the air out of one at a time and swapping the syringe round?
i need to do a drawing to show you what i mean.... imagine you have two one way valves attached to the end of the syringe, youll work it out :)
am i sending you a large syringe ? (iv got a few from work)
laser cutting ally plate
By i2i in forum Tool & Tooling TechnologyReplies: 12Last Post: 21-02-2013, 08:47 AM -
FOR SALE: 45 by 90 ally profile
By johngoodrich in forum Items For SaleReplies: 5Last Post: 13-09-2011, 06:45 PM -
RFQ: anyone wanna quote me to cut some ally?! and....
By robmurf in forum Projects, Jobs & RequestsReplies: 2Last Post: 01-09-2010, 01:16 PM -
NEW MEMBER: anyone wanna quote me to cut some ally?! and....
By robmurf in forum New Member IntroductionsReplies: 2Last Post: 01-09-2010, 10:31 AM -
Model Engineering Exhibition @ Ally Pally
By irving2008 in forum General DiscussionReplies: 6Last Post: 18-01-2009, 10:15 AM
