Thread: Clarke Lathe
11-08-2010 #41
Thanks Irving.
All sussed now,theres a little tensioning plate spring recessed in the shaft under the dial, a little bending of the tensioner plate and its gone a bit stiffer now.:clap:
11-08-2010 #42
Lathe is allnice and clean now,but I want to swap over the chuck and spindle size to the larger size I have and use the smaller chuck possibly as a fourth axis?
Problem is I don't have a press to remove the bearings fom the stock casting,any ideas folks? short of buying a bearing puller?.
11-08-2010 #43
Go find a local gearbox repair place, they should have a suitable press.. and they can push the new ones in for you, keeping them properly square... bearing puller is fine for wheel hubs etc, but not for precision bearings...
12-08-2010 #44
When boring,does one maintain the same height as per outside turning ie center the tip of the tool for middle or just below middle of the workpiece?
12-08-2010 #45
Whiplash from overhaning rod sticking out the back end of the spindle,how do you overcome this?
12-08-2010 #46
12-08-2010 #47
12-08-2010 #48
Cheers,Irving.
I wasn't sure about using a sleeve loaded in the spindles rear,I'll cut a bit of broom handle off her indoors broom,she won't fly around as fast then. lol
Whats the stronger material Delrin or Nylon? going to purchase some on ebay to account for this type of scenario.
12-08-2010 #49
all depends on what you plan to do...delrin is harder wearing and the better engineering plastic generally, Nylon is cheaper... Nylon is good for rollers and stuff where friction is low but there's not much sliding movement... delrin is the better choice for things such as leadscrew nuts where there is a trade off between friction and wear...
12-08-2010 #50
Its only for the rear spindle inserts for a couple of different sized longish bars to stop the whiplash.
Just turned this threaded rod down from 12mm to 10mm for the bearing,chuffed I am... don't want to push it on all the way just yet as the end bit needs a screwthread on it tolockthe bearing in place,mind you it doesn't really need it as the bearing is a tight fit.
Forgotto say,this is stainless steel.Last edited by GeorgeD; 12-08-2010 at 10:49 AM.
Clarke CL300 with dodgy Tailstock
By booski in forum Clarke LathesReplies: 15Last Post: 02-12-2013, 05:26 PM -
FOR SALE: Clarke cl430 Lathe for sale
By Swarfing in forum Items For SaleReplies: 6Last Post: 13-05-2011, 12:43 PM -
The sows ear, a Clarke Metalworker Mill / Lathe conversion to cnc
By FatFreddie in forum Conversion Build LogsReplies: 15Last Post: 03-12-2010, 02:46 AM -
FOR SALE: Clarke CMD10 Mill for Sale
By rckeith in forum Items For SaleReplies: 0Last Post: 28-07-2010, 01:13 PM -
FOR SALE: clarke cmd10 milling machine - £200
By scotty in forum Items For SaleReplies: 4Last Post: 28-03-2010, 02:21 PM
