Thread: Clarke Lathe
22-08-2010 #71
22-08-2010 #72
How do FF.
Its a thin piece of card,but to be honest I didn't think that would be the problem as I picked some tin can up yesterday for shimming and its the results are the same.
I'll get some new tooling this week and see how I fair from there,just could be the nature of the beast ie hardened stainless steel?after all these machines lack a bit of oomph in the torque/power,I mean 300watt motor...c'mon:lol:.
No problem with ally or delrin.
22-08-2010 #73
22-08-2010 #74
The key to getting a good finish is stopping the tool deflecting while cutting, there are several ways to ensure this...
All components between the tool tip and the workpiece must be rigid, not rigid as cant move them with your fingers but rigid as in cant move them with a crowbar! Card is a complete no no, even tin can shim needs to be flat, clean with at most three layers and the tool needs to be well clamped down.
Keep cutting forces to a minimum - deflection is proportional to force. Make sure the tool tip is very sharp - use a high power magnifying glass to examine it and sharpen if it looks at all rough or rounded. It can help to put quite a lot of top rake on for finishing but this tends to make the edge fragile so you have to be careful. You can also use a more pointy tool (technical term) but you then need a finer feed.
Depth of cut, depending on the material, a cut the thickness of paper (0.1mm) might be considered a fairly heavy finishing cut ;-)
Coolant will help protect the tool tip and keep it sharp, if you don't want to use a stream of coolant then the Rocol stuff is pretty good.
The replaceable tip tools tend to be relatively blunt as they're designed for production use on heavy duty machines. It's possible to get sharp ones but carbide is prone to chipping so they are fragile (if you stall the lathe and then rotate the workpiece backwards to free it off, you'll more than likely chip a carbide tool) so I'd recommend HSS tools for a lathe this size.
HTH
Mark
The Following User Says Thank You to FatFreddie For This Useful Post:
26-08-2010 #75
Hi Irving
I'm struggling here on the Lathe,basically I'm having trouble parting-off...the lathe judders and for the life of me can't understand why I'ts proving difficult to part-off?
Last nightI set the gibs as they were a bit loose,today I got some new tooling and blanks,I've tried parting-off at different speeds,the tool is marginally belowthe center...I used the live center to set the tool up.
Stainless Steel bar,had to cut the workpiece of with a grinder :lol:..it ain't funny:cry:
Any pointers as to whats wrong?
27-08-2010 #76
Problem solved,it would seem these Lathes struggle to part-off on hard material and the only remedy is a roller bearing change for the naff standard ball bearings
that come standard.
Now I will have to change em,thank god I don't have to turn a bit off the larger spacer on the spindle because this model doesn't have it,only the thinner plastic spacers which are easily grinded down on a table grinder.
27-08-2010 #77
Forgot to mention,whilst scouring the net for info on these lathes I happen to think up an idea for DRO's on the cross-slide and compound but how to fit them?
In Lidl they had those cheap digital calipers which work on the same basis as the DRO's plus they readout inches and mm...so Lidl here I come.. :whistling:
I suppose given a little lateral thinking these couldalso be adapted to other machinery?
This will do nicely sir. :naughty:knowing my luck theywill have none left.
Clarke CL300 with dodgy Tailstock
By booski in forum Clarke LathesReplies: 15Last Post: 02-12-2013, 05:26 PM -
FOR SALE: Clarke cl430 Lathe for sale
By Swarfing in forum Items For SaleReplies: 6Last Post: 13-05-2011, 12:43 PM -
The sows ear, a Clarke Metalworker Mill / Lathe conversion to cnc
By FatFreddie in forum Conversion Build LogsReplies: 15Last Post: 03-12-2010, 02:46 AM -
FOR SALE: Clarke CMD10 Mill for Sale
By rckeith in forum Items For SaleReplies: 0Last Post: 28-07-2010, 01:13 PM -
FOR SALE: clarke cmd10 milling machine - £200
By scotty in forum Items For SaleReplies: 4Last Post: 28-03-2010, 02:21 PM
