17-08-2010 #8
You didn't mention just how many amps at what voltage you actually need. I built about a year ago a design from Elektor that works in a similar way to a Switched Mode Power Supply, but with most of the dangers to the user removed.....also, with the chips noted, you can have 10 amps at up to 40 volts. With other chips, you can have even higher voltages......if you want full details, I can post them here for you, just let me know......it was easy to build, easy to set up and is around 85% efficient, almost as efficient as a top SM Power Supply....and with the plus that I know EXACTLY how it works and I can easily repair it if ever needed.....all the clever stuff is in two identical chips.....
Regards
Andy
can I have my power supply in a seperate box?
By nobby in forum General ElectronicsReplies: 1Last Post: 12-06-2013, 11:33 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
FOR SALE: 50V 20A Power supply
By Jimmybristol in forum Items For SaleReplies: 8Last Post: 30-05-2011, 11:01 PM -
power supply problms
By Scott in forum General ElectronicsReplies: 13Last Post: 11-07-2010, 12:58 PM -
power supply
By hitmythumb in forum General ElectronicsReplies: 6Last Post: 21-06-2009, 10:27 AM
