    jonm's Avatar
    Location unknown. Last Activity: 19-06-2011 Has been a member for 9-10 years. Has a total post count of 89.
    irvine this may be one for you
    would it be possible to use one 35mm profile rail and one bearing block on a z axis the block is 70 mm wide x 112
    dynamic load for block is 49kn
    just a thought
  2. do you mean vertically? for a plasma torch?
    This would work, but a masive overkil, you could do the same with one HGR15 and HGW15
    jonm's Avatar
    irvine, gary
    for a wood router
    It would be better to use two of the HGR15 rails.
    The HGR35 would work, but it is better to keep the height of the rail as low as possible, so using two smaller rails would e better.
    jonm's Avatar
    gary
    would two 15mm rails and one bearing per rail work
    For a plasma it would not be a problem, but a router it would be better to have two bearings per rail.
    jonm's Avatar
    gary
    might just go for your 20mm rail kit
  1. mounting profile rail - Hiwin Manual vs. typical approach
    By dsc in forum Rails, Guideways & Bearings
    Last Post: 11-12-2013, 10:43 AM
  2. round, supported or profiled rail?
    By mocha in forum Rails, Guideways & Bearings
    Last Post: 26-07-2012, 03:44 PM
  3. FOR SALE: New Hiwin HGH15 bearing blocks / carriages profile rail
    By Jonathan in forum Items For Sale
    Last Post: 06-11-2011, 05:26 PM
  4. Hiwin Profiled Rail Question
    By Normsthename in forum Marketplace Discussion
    Last Post: 02-08-2010, 07:02 PM
  5. WANTED: WANTED: HIWIN LG25 rail
    By Smiler in forum Items Wanted
    Last Post: 01-03-2009, 08:13 PM
