That's the output of the relay, if you're using it, the "NO" is the normally open connection, the "C" is the common and the "NC" is the normally closed connection. What that means is the relay will make a connection from the common to the normally open when the relay is energised, and when the relay is not energised the common is connected to the normally closed
Can't reply to a thread
By Washout in forum General DiscussionReplies: 9Last Post: 24-10-2012, 06:56 PM -
Thread Engagement
By GTJim in forum General DiscussionReplies: 1Last Post: 12-09-2012, 11:13 AM -
Thread Tapping?
By Tenson in forum Tool & Tooling TechnologyReplies: 6Last Post: 04-05-2012, 04:51 PM -
Thread diameter
By Daniel in forum General DiscussionReplies: 7Last Post: 23-02-2012, 06:18 PM -
Pipe thread in 22 tpi???
By Robin Hewitt in forum Machine DiscussionReplies: 3Last Post: 21-09-2010, 11:19 AM
