Page 3 of 3 FirstFirst 123
  1. #21
    bobc's Avatar
    Lives in Eastbourne, United Kingdom. Last Activity: 23-02-2015 Has been a member for 9-10 years. Has a total post count of 19.
    Looks like a nice project. My 3D printer uses M8 threaded rod, it works surprisingly well considering the price. I have always had doubts about the accuracy, but when printing at a resolution of around 0.1 mm it is not critical. The bigger problem I have is "wobble", although I think that is more of a design issue with the printer frame.
    Unfortunately, the price hike to leadscrew is pretty steep. I priced up 4 sets of 10mm leadscrew and it was way too much. I would be better putting it towards a new machine.
    A couple of questions: how is the wire tensioned? Presumably it has some stretch to allow for change in distance while it is cutting a profile?
    Is there anything special in the software setup to handle the fact you effectively have two X,Y coordinates? My understanding of the GCode machine model is that all axes in a G1 move are synchronised and coordinated, so it does not matter how or where the axes are.
  2. Hi Bobc
    Wire will be tensioned by spring to allow for the x axis on both towers to move interdependently for cutting tapered wings. I'm testing out different software but profili2 pro has 4 axis for foam cutters and foamworks generates the gcode as well.
    post some more pics up soon when I have it cutting some foam
    Keith
  3. Hi Guys
    Few more updates. I've added home/limit switches and run some test cuts. Its starting to become a bit easier now. Here's a link on my website CNC Config Mach3 and TB6560 with some sample cuts and setup.
    I've documented the configuration so anyone else using the same set up can save a bit of time and head scratching.
    The biggest learning curve I think is getting all the software to work, but I use Mach3 and profili2 which do good job. I'm also looking at InkScape as there is a gcode extension for it. Might use this to cut fuselages.
    Keith
  4. The Following User Says Thank You to rckeith For This Useful Post:
  5. This video show the flying wing I made with the cnc foma cutter its on my video page RC Video's - rcKeith | Projects
    It was a quick test to see how it could cut wings and what a fantastic flyer its is. Its my favorite flyer now. Goes like stink and can fly at snails pace as well.
    Have now purchase DevFus software to make fuselages which I going to test on a 50 inch wing span Hurricane.
    Keith
  6. I've added a lot of details to my build including plans, instructions and parts/cutting lists all at my website www.rckeith.co.uk . I've have a video almost ready that should be up in a few days on using Profili Pro 2 for cutting foam wings which I'll then follow up with one on Dev Fus Foam. I've used these to produce a 50 inch Wing span Hawker Hurricane. A few images below. Not finished yet because of other stuff getting in the way. I'm now looking to build a CNC router probably a Openbuilds OX but also may try and build Mark Carew's Phlatprinter this seem ideal for producing foam models. I like the fact its fairly compact and can produce large parts.
    Attached Images Attached Images
  1. Machineable foam
    By craigrobbo in forum Marketplace Discussion
    Last Post: 03-02-2013, 08:40 PM
  2. Machining Insulation foam
    By Philly in forum Machine Discussion
    Last Post: 28-01-2013, 12:38 AM
  3. CNC Hot Wire Foam Cutters
    By HotwireCutter in forum Manufacturer News
    Last Post: 02-05-2012, 09:04 PM
  4. NEW MEMBER: First post - want to build a cnc hot wire foam cutter
    By rckeith in forum New Member Introductions
    Last Post: 12-12-2010, 12:23 AM
  5. Software for foam cutter - any recommendations
    By rckeith in forum Machine Control Software
    Last Post: 08-08-2010, 10:14 AM
