    I fancy giving this epoxy leveling technique a try. Can anyone recommend a good source and type of epoxy for the job.
    CNC routing and prototyping services www.cncscotland.co.uk
    ADD ME ON FACEBOOKS
    Quote Originally Posted by gavztheouch View Post
    There are various ones:
    West system 105 with the 209 slow hardner
    Easy Composites
    Reactive Resins Syntac EPAFD Slow Cure Epoxy Resin Pack
    Infusion resin's
    To name but 4. Most on here use Wests, Eddycurrent and I (although I've not mixed it correctly) have used Reactive resin and Jazz uses Infusions resins....take your pick!
    Neil...
    Build log...here
    Neil Sorry about the cock up, it happens, its called a learning curve. I was going to comment on the mixing in your picture but now you are doing it again I will. You appear to have mixed it with a round rod I don't think that is good I think you need to do it with a flat piece of thin plywood or plastic as it will mix better. It says that on the WestSystem info about the correct way to mix and not to have the temp to high 20C is about right. Hope you don't mind me pointing this out. ..Clive
  4. The Following User Says Thank You to Clive S For This Useful Post:
There are currently 20 users browsing this thread. (0 members and 20 guests)
  4. BUILD LOG: A3 Router Build
