23-06-2014 #2
23-06-2014 #3
If your driving both with single motor then yes you'll need Nema34 about 6 to 8Nm but make sure you use high power drives for best performance.
My personal preferance is screws connected with belts but if you run slaved motors well within there capabiltys then you shouldn't have any troubles. The only thing I would recommend and will only Use with slaved setup's is Digital drives that have stall detect and provide a Fault signal which you can use to E-stop the system. If you do this then your safe with minimal risk of damage to screws when things go wrong.
What will the main use be.? and what size/pitchscrews are you using.?
24-06-2014 #4
I'm using RM1610 screws....main use will be plastics a bit of aluminium and possibly light cast iron work (spot facing cast iron couplings etc.) with a bit of balsa and lite ply cutting. I've got AM882's at the moment, they do up to 8.2A so a SY85STH118-6004B Nema 34 rated at 6A should be OK to drive?
24-06-2014 #5
Neil it's the 70-75Vdc limit of the drives that causes the problem with Nema34 motors. Larger motors need 100V+ to get decent speed out of them and that's why High power 240 Drives are best. Now with 10mm pitch screws and 75Vdc you'll get approx 8mtr/min of usable speed with a decent weight gantry. You'll possibly get higher speeds but they won't be reliable and could stall if pushed hard. That is more than enough for cutting most soft materials so again personally I'd go with single motor setup for reliabilty issues and to remove all doubt.!
That said AM882 are good drives for slaving has they have stall detect and can be used to stop system so either setup would work. You'll possibly get slightly higher rapid feeds from Twin motor setups as motors spin faster but that doesn't mean you'll get higher cutting feeds as the 34's tend to have more torque higher the RPM scale then drop off quickly.!
30-06-2014 #6
Cheers Dean, I'll probably go single Nema 34 and 240V drive!!
30-06-2014 #7
There are currently 22 users browsing this thread. (0 members and 22 guests)
BUILD LOG: A3 Router Build
