01-04-2015 #571
Dean, what would be the best way to do it then? I'm going to have 2 proxys on each axis (maybe not the Z but I've not worked out where/how to put them it yet) as I want them tucked away (the Y axis ones are going to be in the enclosed gantry and the X axis ones are going to be mounted on the machine sensing the ballnut housing)
Graeme, I want to rely on hardware to control the driver enable and just inform the software that there's been a positional error and not rely soley on the software to get the signal and then inform the driver of the error.
01-04-2015 #572
Pic of proxy data sheet showing they can be wired in series...
01-04-2015 #573
Neil Would you mind putting a link up to the data sheet. Thanks Clive
01-04-2015 #574
http://uk.farnell.com/webapp/wcs/sto...&storeId=10151
The one I photographed was out of the box...
01-04-2015 #575
Started on some wiring of the power circuit....
Those cable markers are a right bugger to get on, that's what's taking most time...Last edited by njhussey; 01-04-2015 at 05:01 PM.
The Following User Says Thank You to njhussey For This Useful Post:
01-04-2015 #576
Looking good!
The CS Labs controller was such a pleasure to work with I have to say :) so well laid out. Definitely a good choice on that one.
The whole build is coming together nicely look forward to seeing it move soon!
The Following User Says Thank You to fvfdrums For This Useful Post:
01-04-2015 #577
Cheers Francis...I'm doing the connections between the drivers and the IP-M tomorrow and then I'll start on the safety side of things...cant wait for it to move either it's been about 5 years in the making!!
01-04-2015 #578
That way is fine Neil I was more pointing out the side affects of wiring in series before some one chimed in that you can't wire prox switches in series.
One thing I meant to ask is that your not planning on sharing Home and Limit switches are you.? Because if so then it won't work.!
01-04-2015 #579I see you have the right tool at the ready.Started on some wiring of the power circuit....
.Clive
01-04-2015 #580
There are currently 12 users browsing this thread. (0 members and 12 guests)
BUILD LOG: A3 Router Build
