Page 12 of 82 FirstFirst ... 210111213142262 ... LastLast
  1. #111
    Sounds like yours and my machines electrics will be the same I was going to look into the closed loop system but for what I'll be using it for I couldn't really justify the extra. I've also been looking at that as I was wondering if I could use the PWM output to control my RC Speed Controller which will be powering my spindle. Sounds like some combined purchases could be made here!!! Yes seen a few threads, I'm fine mechanically but anything electrical leaves me cold...
    Neil...
    Build log...here
  2. #112
    I own a soldering iron and I even switched it on once...
    I'm actually quite interested in the electronics I just don't really have time to learn as much about it as I would like. I think I'll probably build the PSU as it's only a dozen or so components, more complicated magic will have to wait.
    If you want to get together for a brain storm on the electrics or to put together a combined purchase just give me a shout.
  3. #113
    More than happy to get together for a brainstorm on the electrics, would be good if we both have the same as then we can help each other out (seeing as we only live a couple of miles apart!) in case of problems. I'm definitely going to build my own PSU but will need to check from the experts on here that I'm getting the correct parts.
    Will give you a shout when it's time to get the electrics, in turn give me a shout if you're ready before me to get them as I'm going to concentrate on the build of the frame first as the electrical bits have a 12 month warranty and I'll want that to be as near as possible to the end of the build...
    Neil...
    Build log...here
  4. #114
Name:	Chip cover-1.jpg
ID:	10146Click image for larger version.
Name:	Chip cover-X axis belts.jpg
ID:	10147Click image for larger version.
Name:	Chip cover-Y axis.jpg
ID:	10150OK Dean, switched the gantry around again to how it was before. Have put a folded aluminium enclosure over the Z axis, on the bottom of the Z there will be a rubber cover (5mm thick rubber with cut outs for the rails) to stop chips going up into the bearings. Have put deflectors on the X axis to stop chips hitting the linear rail, also put a deflector down the bottom so chips slide into the bin. Have altered the ballscrew mounting so it's on 20mm block and not the aluminium box section as I'm not using that anymore. I will also put a cover over the X axis belt and steppers.
    Couple of questions now...
    1. I'm going to use 1 stepper and belt (T5, 15mm wide) and pulleys to drive the X axis, what number teeth pulleys would you recommend? I take it that it's worth getting spare pulleys and belts so that the option of 1:1 and 1:2 (stepper to ballscrew) is available?
    2. For the belt idlers/tensioners I was going to use skate bearings (as I've got sh*t loads of them) and penny washers, I couldn't see any specific idlers for the belts?
    Neil...
    Build log...here
  5. #115
    Depends on how your having belt system.? My machine is setup with 2 pulleys bolted together on one screw with a single pulley on other. A short belt goes from motor to first pulley then connecting belt goes between screws. The ratio is 1:2 motor with 40T and first pulley 20T Connecting pulleys are 36T. I then have 2 spare pulleys for 1:1 or 1:3 ratio 20T & 60T.
    Connecting pulleys could easily be 20T for simplicity sake but I just happened to have spare 36T so used them.
    Don't go smaller than 20T other wise you don't get good tooth engagement and the belts wear quicker or worse they can jump. I'd also use HTD belts/pulleys not T5 has thou they are very similar the HTD just seem better fitting belt.
    Yep skate bearings and large Penny washers work fine for idlers.!!
  6. #116
    I was thinking along the lines of this, but measuring it is just over 2000mm long so might have to re-think it...oh and before someone comments I know it will have to be a belt and not a piece of string
Name:	X axis belt.jpg
    Neil...
    Build log...here
  7. #117
    Nice bit of string you've got there ;-)
    Looks like your coming to much the same conclusion I did. I'm sure a belt will work but it's certainly a long belt. I decided I'd rather use two steppers and have the open back that I could shove long work out if needed. Feels like one of those six of one half a dozen of the other decisions.
  8. #118
    I'm not planning on being able to shove long work in and out, won't be practical anyway as I'm limited by the roof and floor as mine's almost vertical. I've just added some bracing to the legs so that's made the cutting area smaller with my previous width of Z axis....so I've narrowed it. I'm hoping that it's not too narrow, it's now 145mm wide. I'll have to check the 15mm carriages but I think they'll be ok at that width...
Name:	Additional Frame Bracing.jpg
ID:	10165Click image for larger version.
Name:	Additional Frame Bracing-2.jpg
    Neil...
    Build log...here
  9. #119
    Just been looking at PV solar panels, leisure batteries and charge controllers for the shed so I can have some 12V LED lighting in there as well as being able to charge my RC LIPOs etc...interesting little project
    Broken the different frames out and coloured them so they stand out a bit more, also did it with them all together.
Name:	Mounting Frame.jpg
ID:	10172Click image for larger version.
Name:	Router Frame.jpg
ID:	10173Click image for larger version.
Name:	Inclined Rev 6 CNC Router.jpg
    Neil...
    Build log...here
  10. #120
    I've got a friend who's PV mad, he's just bought a load of panels so I can ask him what he's got if you'd like?
There are currently 13 users browsing this thread. (0 members and 13 guests)
  4. BUILD LOG: A3 Router Build
