23-12-2014 #361
23-12-2014 #362
Wow, that's one heck of a nice job you've done there. I will most certainly be asking for guidance when it's my turn to run the epoxy gauntlet.
The Following User Says Thank You to Wobblycogs For This Useful Post:
23-12-2014 #363
Cheers Graham, as with everything the key is in the preparation.
I was looking at the leaks before I left work this afternoon and all the leaks are actually where the mdf was joined. Next time I'll have more time and use wood glue and then seal the joints with sealant. Will also use more silicone sealant under the moat as it's easy to get off the metal.
25-12-2014 #364
Sat down after Christmas dinner
and I really want to pop into work to see how the epoxy is doing.....there's no hope for me I know!
I have decided to use the 20mm thick Ali plate (don't know the grade) as a bed for it. I'll buy the bits for the Y axis gantry and the Z axis in eco cast, especially as work are paying for itill get it on order when I get back to work so I can crack on ASAP.
28-12-2014 #365
Just popped in to work as I was round the corner recycling some of the Xmas paper, boxes etc. It's set nice and hard, shiny and smooth. It's going to be a pain getting the moat off and the silicone sealant but overall I'm happy with it.
The Following User Says Thank You to njhussey For This Useful Post:
28-12-2014 #366
Great job, looks like that epoxy came out perfectly! I've had some good luck removing sealer with a hard wire brush.
05-01-2015 #367
Ok so the MDF moat is off, wasn't too bad to get off in the end.....but in hindsight I'd make sure the MDF was not oily (been hanging around in the machine shop for a couple of months) and put brown parcel tape on it as it doesn't stick to it and comes off cleanly. I'd also put parcel tape on the steel where the moat was going so that the silicone came off easier too. It's nothing that a bit of elbow grease won't sort. I've found the best tool to scrape off the MDF is an indexable lathe tool...not scraped it fully in the below picture
Here you can see the meniscus, the epoxy is about 7mm thick.
Here you can see the difference between the wrong ratio mix of epoxy and the correct...the incorrect is on the right and although you probably can't see it the epoxy is a bit grainy looking and opaque whilst the correctly mixed epoxy is far more translucent and shiny...
05-01-2015 #368
One rail is done and the other is half done. More MDF stuck to the epoxy on this side so it's taking longer to get off...
05-01-2015 #369
Quick video of me getting a section of the MDF and silicone sealant off today.
Also filing down the meniscus on both sides.
The Following 2 Users Say Thank You to njhussey For This Useful Post:
05-01-2015 #370
If its not to late in the clean up game, get yourself down to the nearest UPVC setup, ask them for a bottle of PVC cleaner, you want the clear stuff not the "jiff like" stuff, it's great I use it for everything it's designed to desolve silicon sealant and it dose so like magic, it doesn't turn it into a pasty mess like you would think it just somehow frees the silly up enough that you can just peel it off.
Seriously, get some anyway it removes all sorts really well. I use ISOPROPYL for some stuff but the PVC cleaner works great for allot of things, £2.50 here for a one 1ltr bottle.
.MeLast edited by Lee Roberts; 05-01-2015 at 09:27 PM.
BUILD LOG: A3 Router Build
