23-01-2015 #421
23-01-2015 #422
Opens OK in Foxit Reader
Mike
23-01-2015 #423
Well it worked for me. I didn't know PDF's could do that, I must investigate more. The rendering is as good as you get in something like SolidWorks. The design is looking good and really coming on a pace now.
23-01-2015 #424
Cheers Mike...
I've not played with the clours and rendering yet, will do if I get time. We've bought an add on that means you can make animations, can't wait to install that and have a play with it (bought it to do work animations for our new web site that we're currently designing)
Again cheers, just doing the dimensioned drawings for the pieces now so I can start the machining...looking forward to that!] The design is looking good and really coming on a pace now.Last edited by njhussey; 23-01-2015 at 02:47 PM.
26-01-2015 #425
Set up a straight edge parallel to the master rail 300mm away and put a DTI on a carriage and moved it up and down the rail. There's about 0.25mm of twist/dip mostly near the rear of the machine.
Only conclusion I can accurately draw however is that my DTI is too cheap as it moves all over the place i.e. doesn't return to zero after going up and down a few times...need a better quality DTI....
26-01-2015 #426
Did a bit of drawing as well today...
26-01-2015 #427
26-01-2015 #428
28-01-2015 #429
Looking at the rail today I put the straight edge on the rail and tried the feeler. There's a dip at both ends (last 6 inch) of the rail so ill have to shim that before carrying on much further :(
Not done much else on the machining as been making a tapping arm today...
03-02-2015 #430
Needed some 20mm aluminium for a clamp for the pantograph arm I'm making at work so put the big plate I've got on a table and used the Evolution circular saw to cut the plate to size for the bed. The 100mm strip cut off will be used for blocks for mounting the ballscrew mounts on etc...
The Following User Says Thank You to njhussey For This Useful Post:
There are currently 37 users browsing this thread. (0 members and 37 guests)
BUILD LOG: A3 Router Build
