19-03-2015 #521
19-03-2015 #522
Missed that first time round, nice idea looks cool.
Not sure on Clive and the chocblock, I guess he's right but what to do...
I guess you need somthing of a busbar, mini consumer unit? Or is that ott?
.MeLee
19-03-2015 #523
Neil what do you thin: http://www.directindustry.com/prod/s...5-1058789.html
Or somthing like this: http://www.12voltplanet.co.uk/power-...s-busbars.htmlLast edited by Lee Roberts; 19-03-2015 at 05:54 PM.
Maybe mount the MCB's on the din rail with a busbar and then a seperate din mounted busbar for the -ve?
19-03-2015 #525
:) sounds like a plan :), just seen these: http://m.ebay.co.uk/itm/321061386290
I remember now...EddyCurrent linked to that in his build...looks like a good solution, ta!
19-03-2015 #527
19-03-2015 #528
These seem ok and you would get the fuses for the drives (if you want them) you would need two of them fuse in the +ve and bridge the -ve solid (no fuse) cheapo choc blocks will melt if the screws come loose. Clive
ps the others with the led in would be no good as you will be running 70V ish.Last edited by Clive S; 19-03-2015 at 07:08 PM.
19-03-2015 #529
20-03-2015 #530
How about soldering the 1 wire from the caps directly to 3 smaller wires and connecting them to din terminals.
Then connecting from there to MCB's before going to the drivers?
BUILD LOG: A3 Router Build
