Page 76 of 82 FirstFirst ... 26667475767778 ... LastLast
  1. #751
    Great stuff Neil - bet that felt like a big milestone reached.
    Will be nice to see how it runs in its new configuration.
    Chris
  2. #752
    You and me both Clive. Will be interesting when I fire t up again tomorrow. Need to make some rubber bump stops asap to park the gantry at the bottom safely...think I have some polyurethane rod somewhere.
    Neil...
    Build log...here
  3. #753
    Chris
    Cheers Chris, it's a relief and will spur me on to get it finished now.....till something else pops up.
    Neil...
    Build log...here
  4. #754
    Lives in Marple Stockport, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    How about those round rubber door stops with a hole in the middle? https://www.google.co.uk/search?q=ru...HcJvCbMQsAQITg
  5. #755
    Good idea Clive.....the stops have to be about 60mm (will measure later) and I think will have to be rectangular....more research needed I think!
    Neil...
    Build log...here
  6. #756
    Control box & VFD on the wall....
    now working on the electrics.... got the correct tool out....
    Neil...
    Build log...here
  7. #757
    Neil Do you think you will need another bracket to bolt the frame to the wall at the top, shimmed as to not twist the frame Hope you are only using he hammer to tap the connections into place
  8. #758
    There are 2 additional bolts half way up bolting the frame to the wall...shimmed with custom cut bits of pipe 😁 the base is shimmed and bolted at all 4 corners so I'm hoping it's still all square....will tell when I first go to cut later today...
    Hammer was, as you suggested, to tap in the wires...who needs screwdrivers?
    Neil...
    Build log...here
  9. #759
    Neil...
    Build log...here
  10. #760
    Don't seem to be able to see any chips though . Just thinking aloud how about a brake operated with a solenoid that operates when you lose power. It could be on a counter weight steel cable over the top (on a pulley) and then brake the cable.
  4. BUILD LOG: A3 Router Build
