22-08-2016 #781
Hi Dave, I wear one of those twin filter painting breathing masks as I know MDF dust is very nasty stuff (I'm sure balsa dust is equally nasty)....look a knob but saves the lungs! I'm building an enclosure round the machine and there will be an extraction system (6" tube and for the enclosure which will also be for the lathe, welder and milling machines which will vent outside. The dust shoe will be connected to a vacuum cleaner (Nifilsk 30T vacuum) via a DIY cyclone dustbin.....
22-08-2016 #782
Excellent, I use one of those masks when doing a lot of grinding or finishing etc, keeps the black snot under control :)
02-09-2016 #783
Got fed up with the end cross supports....cut through one and dims between beams didnt change....will use external bolted braces....just gained some extra length on my machine 😁
05-09-2016 #784
Had a good purchase from eBay last week, a Camvac for under 1/3 its retail price. Its like new and works well.
Made a rough dust shoe out of 12mm ply and a bit of draught excluder. Just got to test it works ok before working out how to fix it on so there's access to change the bits and do the probing...
Any ideas anyone on how best to do this? I'm leaning towards neodinium magnets holding one side on...
Sent from my HUAWEI VNS-L31 using TapatalkLast edited by njhussey; 05-09-2016 at 01:35 PM.
24-09-2016 #785
Put the home switches on X, Y and Z, wired back to the CSMIO IPM and set up in Mach3...all working as should but still need to put "targets" for them on the machine....
26-09-2016 #786
Ok so I've dome the homing switches and all work. Quick vid showing this.
Seems to work ok.....however I've had to reverse the Z axis to get it to home and now its all to cock....if I try to do a tool zero with my touch plate then it goes up instead of down....just looking at the settings in Mach3 to see what I need to reverse/do but if one of you experts could point me in the right direction id be eternally grateful
Sent from my HUAWEI VNS-L31 using TapatalkLast edited by njhussey; 26-09-2016 at 05:32 PM.
26-09-2016 #787
Home Neg in Homing Limits screen.....
Sent from my HUAWEI VNS-L31 using TapatalkLast edited by njhussey; 26-09-2016 at 05:33 PM.
26-09-2016 #788
26-09-2016 #789
You're correct Clive, knew there had to be a setting but wasn't sure till I read the manual.
Set my park position too for changing bits and also for parking the gantry at the end of the day....slowly getting there with it.
Limits next, then enclosure, counter weight, proper dust shoe, LED lights...the list goes on!!
26-09-2016 #790
Neil are you sorted.?
Either Home neg are use the Reverse option but will depend on how axis is setup. one of them combo will sort you.
BUILD LOG: A3 Router Build
