    Some numpty in the (presumably) Chinese factory has jammed the drill arbour shaft so tight in the spindle that no amount of smacking 7 bells of s**t out of the drawbar is getting it out. I've been hitting the nut so hard that I now can't get a 19mm spanner on it....getting seriously p****d off with it now.....
    You should be able to lower the quill and knock a drift through the slot in the spindle to release it?
  2. The Following User Says Thank You to Jonathan For This Useful Post:
  4. BUILD LOG: A3 Router Build
