20-01-2015 #411
Yeah its good software, we just got the Mill package that goes with it so should be able to draw parts and then mill them on the router or the next project which is CNCing the mill...
No I can't wait to get stuck in. Taking my time making sure it can be put together etc...
20-01-2015 #412
I found that it could only be designed and drawn up to point, the rest was sorted out as it happened.
20-01-2015 #413
21-01-2015 #414
Been working on the Z axis today, not done it all by any means as work keeps flipping geting in the way...
Not drawn the plates that the Y axis Carriages attach to yet (simple so won't take long) ot the Z axis Stepper plate which is going to have a pocket for the stepper milled into it with slots so the belt can be tensioned. The Z carriages and rails are just blocks drawn to the correct dimensions but with no detail, couldn't be bothered and couldn't see the parts in the online library to download but not looked too hard!
21-01-2015 #415
Put some material back on that front plate it will help with resonance. You only need to remove what you need to remove for the screw to clear.
21-01-2015 #416
Cheers Dean, I'll alter that tomorrow.
Quick question. I was going to use the DIY spindle that I've made but seeing as I'm not paying ill probably get a water cooled spindle and VFD, now is it worth getting the 2kw or 3kw one and which VFD (without going overboard on cost that is!) to get and any recommendations where to get them?
21-01-2015 #417
Keep in mind this info is a bit over a year out of date but I got a 2.2kW water cooled spindle and VFD from Chai for £216 ex VAT. There were places that were a little cheaper but as I was getting other parts from Chai it made sense to get them all together. I also found a load of suppliers on ebay that I wouldn't touch with a barge pole, YMMV, worth a google pre-purchase though.
22-01-2015 #418
22-01-2015 #419
22-01-2015 #420
There are currently 30 users browsing this thread. (0 members and 30 guests)
BUILD LOG: A3 Router Build
