12-02-2015 #441
In the video is your indicator tip running along the other rail - not the rail you're pushing the bearing along? It's hard to see in the video... you will want to indicate from one rail to the other to get them parallel (ish).
Edit: Just realised, looks like you're indicating against the straight edge?Last edited by Jonathan; 12-02-2015 at 10:51 PM.
13-02-2015 #442
Yes indicating along the front of the top piece of Ali. Checked it with a straight edge, feeler and light first. Will indicate off the second rail once the gantry is together.
The Ali top, bottom and front pieces were CNC machined to size in one go (I sent them out to someone with a bigger table than me....cheating I know but more accurate than making a jig and moving the plate along to machine a bit at a time
) and clamped together (not the front plate) so I'm hoping that once it's put together it won't need too much tweaking to get them parallel (ish)
13-02-2015 #443
16-02-2015 #444
More machining today, got a couple of new M4 spiral flute taps which make light work of the tapping for the 15mm THK rails on the front plate.
18-02-2015 #445
Set the Z axis rails parallel by referencing off the plate side for the master rail then referencing the secondary rail off the master...
18-02-2015 #446
Flying along now and looking good.
18-02-2015 #447
18-02-2015 #448
Had to "tweak" some machining on the Z axis stepper mount and also the Z axis back plate...will also have to machine a small pocket out of the Z axis front plate for the ballnut mount as it's not quite (0.6mm) right...
It's going together quite nicely...so far!
18-02-2015 #449
OK so Z axis is together now, couldn't resist a little test with a cordless drill
The machining on the ballscrew is not 100%, there's a wobble on the drill but it's not too bad and I'll be able to live with it.
For the eagle eyed among you you'll notice that there are 8 holes for the ballnut holder....erm not much to say apart from oops
18-02-2015 #450
Does the cordless drill have step/dir inputs to drive directly from Mach3?
There are currently 22 users browsing this thread. (0 members and 22 guests)
BUILD LOG: A3 Router Build
