Ok so pulled the gantry apart and machined the front and bottom plates (M8 counterbored hole in each)
Put it all back together and it's nice and solid...
Control cabinet and bits arrived just now so more stuff to play with
Going over to Wobblycogs tonight to have a catch up, talk CNC Routers and look at his control cabinet to get some inspiration...
11-03-2015 #2
OK quick question. I'm now coming to the end of the mechanical build so my mind's turning to all things electrical
When connecting the CY cable to the stepper how do you folks do it? I was thinking of either via a chocolate block as near to the stepper as possible or probably I'll go with soldering the wires with heat shrink over them and then heatshrink over the whole lot?
11-03-2015 #3
11-03-2015 #4
11-03-2015 #5
11-03-2015 #6
The Z axis stepper will be covered by a cover ill be making from sheet metal to cover the entire Z axis (Jazz's idea) and the Y stepper is enclosed in the gantry (or will be) so the only stepper exposed will be the X axis one, I might look into a cover for that once the machine is up and running. It'll also be tucked away at the top of the router (it's going 80° vertical on its side) at the back so hopefully out of the way.
There are currently 31 users browsing this thread. (0 members and 31 guests)
BUILD LOG: A3 Router Build
