17-03-2015 #511
Ok I'm sold, if both you and Clive say it's better the other way ill put it back how I was originally going to have it!!
I am going to make a cover for the Z axis (just not shown it here) and the back of the Y axis will be covered with an Ali or perspex plate and chip deflectors put on to protect Y axis rails. The X axis belt will be covered. I'll be putting sides on the machine from the X axis rails down to the bed and also at the back to stop chips from flying too far round the enclosure.
I got the markers from Worcester Electrical (WED), not the cheapest I'm sure...
Running out of mechanical things to do now so suppose I'd best stop fannying around and do the electronics.....Last edited by njhussey; 17-03-2015 at 10:30 PM.
17-03-2015 #512
Only thing better is chip control other than that there's very little difference, If want to be Knit picky then could say your original way will give slightly faster rapids but in practise this doesn't matter as it will be more than fast enough.
One thing I will advise is building in some Bump stops at the bottom and when not using for extended periods Park it onto the bumps. This takes strain off the ballnuts and bearings.
I use Gerry's 2010 Screen set which as a PARK position so used this to lightly bump upto stops when finished at end of each day. In use I used the TC(tool change) option to send Gantry to top of machine for loading material tools etc.
You won't regret going vertical. To fully appreciate the difference use the machine in traditional Horizontal position before going vertical.!! . . . Before I retired my old machine it was horizontal for few agonising and messy months. It's replacement as been working for only a few weeks and already the chips flying around shop are driving me crazy, and that's not to mention the room it's taking up.!!
17-03-2015 #513
I've got some hard stops at the bottom end and will be putting some rubber for the gantry to rest against as you suggested this when I first mentioned going vertical. I'll use it horizontally until I've built the frame but it'll have to be on the floor as the tables aren't strong enough to not be shaken to bits with it on running at full chat....
18-03-2015 #514
Today is re-designing the moutning frame/enclosure.....
Had a delivery today, scrapping my original home made spindle design for a "standard" 2.2kW one...
Slight bit of damage where it looks like it was dropped, nothing serious just cosmetic and nothing that can't be sorted with a file! Spindle spins freely and smoothly...
Currently looking at positions for the limit and home switches...Last edited by njhussey; 18-03-2015 at 02:18 PM.
18-03-2015 #515
Started the PSU this afternoon, got to fix the rectifier (need some thermal paste yet) and then decide how I'm going to do the fuses...
19-03-2015 #516
Ok so done the PSU. One thing I'm not certain on is the rectifier wiring. Can you electrically minded people have a look and make sure I've got the connections correct, I think I have but would like confirmation...Thanks!
19-03-2015 #517
Looks right to me ?
The Following User Says Thank You to Lee Roberts For This Useful Post:
19-03-2015 #518
Neil
I would not be happy with the choc block you need some sort of insulation under it as any stray wires could short to the chassis. Also a larger choc bloc might be better as you are daisy chaining the power from one to another. It would be nice to have a separate wire to each from the main. Just my two cents worth. ..Clive
19-03-2015 #519
19-03-2015 #520
There are currently 42 users browsing this thread. (0 members and 42 guests)
BUILD LOG: A3 Router Build
