    Lives in Marple Stockport, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,345. Received thanks 618 times, giving thanks to others 83 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    :) sounds like a plan :), just seen these: http://m.ebay.co.uk/itm/321061386290
    These seem ok and you would get the fuses for the drives (if you want them) you would need two of them fuse in the +ve and bridge the -ve solid (no fuse) cheapo choc blocks will melt if the screws come loose. Clive
    ps the others with the led in would be no good as you will be running 70V ish.
  4. BUILD LOG: A3 Router Build
