    One for power and one for signals and water of course....
    This is the way I have done it because I wanted the chain out of the way. All of the signals and motor power, water etc run through it without any problems. Although I am thinking of removing the water tube and fitting a small rad. with a fan on it on to the Z axis.
    Dean has done this and it works very well ( Just a small sealed system about 1 pint of water).
    Clive, my router is going vertical so that's not really an option for me, looks a great solution though! I'm going to build a frame/enclosure to put it in which will eventually be fully enclosed with interlocked doors (safety because it's at work) which will also stop the chips from being flung all around the shop floor!
Name:	CNC Router with mounting frame enclosure.jpg
    I like the idea of keeping the water cooling on the Z axis, might look at small PC radiators and fans....
    Neil...
    Build log...here
    Something like this
    http://www.aliexpress.com/item/SP-12...043171101.html
    That's the badger Clive!!....
    I'm torn between mounting it on the Z axis or on the enclosure frame. I'm sure that the small volume will be OK but I'm erring on the side of caution and thinking of mounting it on the frame, that way there is a bit more water in the system. I've got a 240V small 200 l/hr pond pump, but it's a submersible one so I might just go with that in a bucket with a lid for the time being and then adapt the water circuit later....decisions decisions!
    Neil...
    Build log...here
    Hi Neil,
    Good progress recently....
    If you want to go down the PC rad and pump route let me know, as I may have a spare 120mm rad (possibly 2), fans and possibly a pump/res unit I can let you have, as I've recently upgraded to 240/280/360/420mm in most of my watercooled PCs.
    Chris
    Hi Neil,
    Chris
    Cheers Chris, that will be great...pm sent!
    Neil...
    Build log...here
There are currently 24 users browsing this thread. (0 members and 24 guests)
  4. BUILD LOG: A3 Router Build
