23-07-2015 #661
23-07-2015 #662
Did a little bit this afternoon...
Cables still need tidying on the end plates and something put there to stop and chafing....
Stocked up on WD40 ready for cutting Ali.....
The Following User Says Thank You to njhussey For This Useful Post:
28-07-2015 #663
Unfortunately not had a chance to do any more on the machine as real work has got in the way. Still I ordered the steel for the frame (re-designed it to a basic frame that I can then box in if required) which came today.
28-07-2015 #664
Frame re-design....hopefully I can keep the number of re-draws to below 6 this time. router is held to the frame with 4 off M12 bolts
The frame is going to be mounted to the wall and floor rigidly and adjustably so it can be mounted level and slightly off the wall to get access to the botls holding the router to the frame (I can see a re-design on its way already...)
06-08-2015 #665
Not much getting done this week on the build.....
lazing by the pool with a few beers seems a better thing to be doing!!!
02-09-2015 #666
Ok so 20 mins on it tonight and ive drilled the holes to mount the 20mm thick Ali base. Just got to notch the front corners and file where the frame welds will be and then the headache of putting the base on, drilling and tapping the mounting holes and then bolting the base on. It's blinking heavy without the base on, still what's another 50kg eh.....
14-09-2015 #667
Up ended the router, b*@@#r me it's quite heavy!
Notched the corners of the 20mm plate and chamfered where the weld beads are. Put the plate on the base and used an 8.5mm transfer punch to mark the bolt holes.
Drilled and hand tapped the plate...
Put it on the frame and tightened the bolts up...
And then put foot pads on and put it down on the floor for the time being....
14-09-2015 #668
Good to see some more progress on the machine. It looks like its getting close to cutting testing?
BTW - what is the cutting area - it looks smaller in the latest pics but I estimate 500x1500-ish mm?
ChrisMy CNC Projects: https://www.youtube.com/imadethisoncnc
14-09-2015 #669
It's 1000 x 500 although I'm not sure I'll quite get 1000....we'll see.
Yes good to make more progress, spending more time on it tomorrow so hoping to get some movement again tomorrow!
15-09-2015 #670
Ok so I didn't connect up the control panel and play with a small surfacing program.....honest!!!
https://youtu.be/SS2O6dHBvqU
BUILD LOG: A3 Router Build
