Had 20 mins before work this morning, drew up a motor mount and this morning cut it out using Trochoidal milling on my router...I wanted to use the "onion skin" method instead of holding tabs but my MDF bed is obviously not level!! The piece finished with the 2 finishing operations around the bosses and outside profile still to do! Still it gives me the opportunity to tweak the design a bit and re-cut it in lunchtime :D
There are 4 off 25mm long aluminium tubes (10mm OD, 6mm ID) to press in to the bosses for spacers which I'll then mill to the same height (should be OK as I did them on the lathe)
Anyway not bad for a first effort I think! Video will be up a bit later....internet connection is soooo slow today!
