05-05-2016 #731
06-05-2016 #732
Here's the bracket after I've made a mess with the Durafix, machined 5mm off the tubes (lathe) and bolted it to the firewall....only got 2 bolts in at the moment but WILL have all 4 in before anything electrical gets connected I promise!!!
Put the nose cone on and fitted the prop (18" diameter x 8" pitch) to see what it was like...
The Following User Says Thank You to njhussey For This Useful Post:
***high pitched voice***
SSSWWWEEEETT!!Lee
23-05-2016 #734
I'm just starting to do the things I should have done before using the machine (Sorry Dean!!) and one thing is a touch plate (limit switches are also going to be dome ASAP) as I want to use Ger's 2010 screenset. Now I'm a bit thick when it comes to electrickery so I wanted to check I was doing this right before even cutting a wire.....
My limited understanding is that I can connect the -VE 24V DC to the tool via a croc clip (or can I permanently connect it to the spindle or frame?), the touch plate is wired to the -VE input (15 in my case)of the CSMIO IPM input and then I put +24V DC to the +VE (1 in my case) input?
Is there a better (correct) way to do it? Sorry for my stupidity
24-05-2016 #735
Right or wrong it works, installed 2010 screenset and used the simple tool zero and yep......it works!!! Had the bit loose in the collet just in case!! Bought a trepanning tool from Wealden as recomended by Dean and set the height to the base and took 1mm off the bed (it's really bad!!) Felt some ridges so tweaked the spindle right by 0.2° and the bed seems pretty smooth now...
Just need to do the limits so I can home the machine and put the fixed tool change plate on (when the new bed is on the machine!) and make the frame....dust extraction unit....put electronics in the box....etc. etc. etc. etc............
26-05-2016 #736
Hi Neil
That looks like a nice cutter - might grab one myself when ordering from Wealden next (I've been very impressed with their routing bits etc. to date).
I always thought trepanning was used to relieve headaches by cutting a hole in your skull - learn something new every day :)My CNC Projects: https://www.youtube.com/imadethisoncnc
26-05-2016 #737
If you have the tool grounded via spindle/frame, you may permanently connect the 0V of your 24V PSU to ground. Then you have only the touch plate wired as you already did (but not pin 1 and 15, eventually 1-14 or 2-15
I find very useful the "Probe Active" green led on the 2010 screenset that I also use. I made a habit touching the tool with the plate every time I use it to make sure it is working as expected.
The easiest and rapid way to find the corner of your workpiece (nonmetal) is by using a "triple edge finder" (or a double edge finder that is easier to make yourself). To find the center of the touchplate hole that corresponds to the corner of the workpiece you have to use the excelent '2010 X-Y Probing Wizard'.
26-05-2016 #738
26-05-2016 #739
Oooops....you are correct, luckily I've got it wired 2 & 15......
Yes got the 0V wired to the frames earth so I just had the one wire to thread through the cable chains....
I don't fully trust it at the moment so like you I check the connection every now and again. I must admit that it's been a complete revelation this screenset and the touch plate, it's spurring me on to do the home and limit switches ASAP now...I find very useful the "Probe Active" green led on the 2010 screenset that I also use. I made a habit touching the tool with the plate every time I use it to make sure it is working as expected.
I was thinking of making a corner touch plate, now I think I will....got some Ali plate somewhere to play withThe easiest and rapid way to find the corner of your workpiece (nonmetal) is by using a "triple edge finder" (or a double edge finder that is easier to make yourself). To find the center of the touchplate hole that corresponds to the corner of the workpiece you have to use the excelent '2010 X-Y Probing Wizard'.
16-06-2016 #740
Well last weekend I flew my plane that I made with my router....so this is a look what I've made on my machine post :)
The Following 3 Users Say Thank You to njhussey For This Useful Post:
There are currently 35 users browsing this thread. (0 members and 35 guests)
BUILD LOG: A3 Router Build
