Page 1 of 4 123 ... LastLast
  1. Ok, so I got bored at work writing a paper on why we don't need to spend another £100k on overpriced Sun disc arrays (don't go there OK, I dont want to discuss it further :twisted:) so I decided to draw up this...
    Its a rev counter with bell n whistles.
    In its most basic form it takes pulses from the rev sensor (on the left), and shows revs on the LCD display.
    It will also take a PWM input (or a voltage input but I haven't shown that on the diagram) from MACH3 or EMC2 and output a PWM signal for a speed controller. It could also output a 0 - 10v as well but I've not shown that bit. So it can act in 3 modes:
    1/ PWM type 1 in, PWM type 2 out
    2/ Voltage in, PWM out
    3/ PWM in, voltage out
    The two preset resistors set the upper and lower bound of the output speed. A commanded speed below the lower bound results in no motion. I've assumed for the moment that MACH3/EMC would control the spindle power relay, but it woudnt be hard to add this here.
    Since we know commanded speed and actual speed it would be possible to provide closed loop control, although that requires some interesting calculations. This chip only has 2k of program memory, so might need to go to its bigger brother for that.
Name:	Rev Counter.gif
    Excellent. are you proposing to build and sell them or will you be publishing the code? I like the idea of closed loop control.
    I take one if your making them, don't think I've got time to build it, not finished the stepper drives yet :whistling:
    :clap:Sometimes the less you say, the louder it sounds!!
    ecat's Avatar
    Location unknown. Last Activity: 08-02-2014 Has been a member for 9-10 years. Has a total post count of 157. Received thanks 5 times, giving thanks to others 8 times.
    Neat :)
    Are you intending to break out the ICP pins? Generally the first thing I do :) Also a resistor on MCLR?
    Once upon a time I found this paper...
    http://www.semifluid.com/classes/PHY...Controller.pdf
    the source contains code for a simple integer based PID loop, though it only controls one way it makes for a good start if you need it :)
    I modified the code to control both ways and tweaked a few things while playing with it, I have no idea what state I left the code in but it's yours if you want it :)
    Code:
    // Variables and constants for P.I.D.
    BYTE thePower;
    short Tcurrent, Tlast, Tsetpoint;
    short iState;
    BYTE  iStateInc;
    //#define iMax 254           // ctd was 1000.00 // Maximum iState
    short iMax;
    BYTE  pGain, iGain, dGain;
    short temp;
    #define ResolutionScale 16
    #define iMin 1.00 // Minimum iState
    #define tempMax (60 * ResolutionScale) // Maximum temperature  ctd temp * sensor resolution. Not a problem if to large a value ?
    #define OPScaleFactor 128              // shift friendly
    #define MaxOP 99
    void InitPid( void )
     Tcurrent = 0;
     Tlast = 0;
     iState = 0;
     pGain = 200; //3;     // for 12 bit resolution keep <= 16 for extra safety
     iGain = 10;     // was 5, see iStateInc too
     dGain = 1000; //1;     // for 12 bit resolution keep <= 16  for extra safety
     iMax = (OPScaleFactor * MaxOP) / iGain;    // 10000 yields max 100% op, no need for more ?
     iStateInc = 4;  // new var, was const 4.0
    void PID( void )
    //void calculatePID(){
     /* The calculatePID() function calculates the error by subtracting the
     desired temperature (Tsetpoint) from the current temperature (Tcurrent).
     It then uses the calculated error to determine the proportional term,
     which is dependent solely upon the error, the integral term, which is an
     accumulation of the error and is used to clean up the final output, and
     the derivative term, which is dependent upon the change in the system.
     The function then adds the proportional and integral terms then subtracts
     the derivative term to come to a power estimate.
    /* // ctd
    *  Derived from PHYS 315 - Cholewiak, Steven - PIC18F252 P.I.D. Heater Controller.pdf
    *  Error increment is capped by the use of iStateInc so immune to bad readings
    *  One way control only. Changed to 2 way
    *  Easy to protect from overflow
    *  Nasty jump at pv = sp, ok if tuned for max output ?
    *  Slow wind down due to 'iState = iState - 1.00;', changed to be symmetrical
    short tempPower;
    short pTerm, iTerm, dTerm, theError;
        Tsetpoint = 0x136;
        Tcurrent = temp;
       theError = Tcurrent - Tsetpoint;   // ctd swapped these over
       pTerm = pGain * theError;
       dTerm = dGain * (Tcurrent-Tlast);  // one blip per change, hardly worth it for slow systems imho
       if( theError > 0 ) {   // ctd was >=0
            iState = iState + iStateInc;
       else {
            iState = iState - iStateInc;  // ctd was 1.00;
       if( iState > iMax ) iState = iMax;
       if( iState < iMin ) iState = iMin;
       iTerm = iState * iGain;
       tempPower = pTerm + iTerm - dTerm;
       tempPower = tempPower / OPScaleFactor;
       if( tempPower >= 0 ) {
        thePower = (BYTE) tempPower;
        if( thePower < 30 )
          thePower = 30;
       else
        thePower = 30;
    //   if( Tcurrent < Tsetpoint )
    //    thePower = 30;
       if( thePower > MaxOP ) thePower = MaxOP;
    //   if( Tcurrent > tempMax ) thePower=0;
       Tlast = Tcurrent;
    //     serial_print_hex8( thePower );
        INTCONbits.GIE = 0;
        PWMDuty1Reset = thePower;
        INTCONbits.GIE = 1;
    //130: printf("%f,%f,%lu,%f\n\r", Tcurrent, Tsetpoint, thePower, tempPower);
    I suspect the problem with an integer control loop may be the limited resolution, still, worth a try.
  5. Quote Originally Posted by ecat View Post
    Neat :)
    Yes, just haven't done so yet... there's a few other mods...
    Thanks for the code sample... I have one or two others... no need to keep to integers, there's a full FP library if i need it and enough performance in the chip to use it for this application....
    ecat's Avatar
    Full FP in 2k, could be fun ;-)
  7. Quote Originally Posted by ecat View Post
    Efficient linkr only loads whats actually needed.... its pretty good... I use it elsewhere and it loads <300 instructions for basic floating point math....
    You mean a TALKING rev counter, now that's cool !!
    John S -
    Wow,almost identicle to this one belowthat I was having a look at two nights ago?
    http://www.jeffree.co.uk/pages/revmaster.htm
    Is there not a way to knock one up without the use of a PIC? itmeans I have to buy a programmer or look for someone selling a chip prorammed using their design
    Quote Originally Posted by GeorgeD View Post
    Hey george, I got one of these the other day, im very pleased with it and for what is costs Im amazed..
    fleabay item number:-250641581270
    Rick
  1. Trying to make an ultimate sanding drum!
    By fatguyslim in forum Tool & Tooling Technology
    Last Post: 16-05-2014, 01:32 AM
  2. Can't reply to a thread
    By Washout in forum General Discussion
    Last Post: 24-10-2012, 06:56 PM
  3. Thread Tapping?
    By Tenson in forum Tool & Tooling Technology
    Last Post: 04-05-2012, 04:51 PM
  4. Not Just another Boxford tcl 125 thread....
    By cooliced in forum Boxford Lathes
    Last Post: 18-08-2011, 10:15 PM
  5. Pipe thread in 22 tpi???
    By Robin Hewitt in forum Machine Discussion
    Last Post: 21-09-2010, 11:19 AM
