13-08-2010 #17
My first programmer was from matrix multimedia and i still use it, but i have used many since then, more from curiosity, i dont doubt that the PicKit2 is good in fact i know it is, the programmer/development board i put the link to is going to be completely embeded it will be programmed and tested, and entombed forever (hopefully) and this would seem to be fine, if as in this case someone such as yourself has worked out the circuit. It saves on fabricating a board. If you want to develop several projects over time then by all means a reputable and proven programmer/development board such as Pickit2 would be the way you would go, George was showing some aversion to to using pics and having to buy a programmer for a project, this is an inexpensive way to dip your toes in the water of microcontrolers and if its not for him he's lost pennys instead of pounds..
This board has through the hole plating and good clear screen printing and all the components you need apart from the pic itself, so is within reach of even the complete beginer.
Rick
RickAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
Trying to make an ultimate sanding drum!
By fatguyslim in forum Tool & Tooling TechnologyReplies: 26Last Post: 16-05-2014, 01:32 AM -
Can't reply to a thread
By Washout in forum General DiscussionReplies: 9Last Post: 24-10-2012, 06:56 PM -
Thread Tapping?
By Tenson in forum Tool & Tooling TechnologyReplies: 6Last Post: 04-05-2012, 04:51 PM -
Not Just another Boxford tcl 125 thread....
By cooliced in forum Boxford LathesReplies: 135Last Post: 18-08-2011, 10:15 PM -
Pipe thread in 22 tpi???
By Robin Hewitt in forum Machine DiscussionReplies: 3Last Post: 21-09-2010, 11:19 AM
