12-08-2010 #2
Welcome Andrew
Are you looking to build or buy?
The first obvious problem is that you will need to cut all the way through in one go so a sacrificial bed will be needed and probably double sided tape to stop it moving once its cut.
I guess you'll need small high speed bits to stop the sheet tearing, with a fairly low run out on the spindle so you dont break them. get that sorted and you should be good to go.
This is just my opinion and there will be those who have used an mdf machine with a dremel and got results.:whistling:
The Following User Says Thank You to Ross77 For This Useful Post:
eBay: 8x4 sheet of 25mm thick aluminium plate.
By T0rnado69 in forum Items On eBay UKReplies: 0Last Post: 18-04-2014, 02:01 AM -
Milling Sheet Aluminium
By p1lts in forum Metalwork DiscussionReplies: 8Last Post: 08-03-2014, 12:23 AM -
WANTED: 100mmx100mm 6mm aluminium plate/sheet.
By Isaac in forum Items WantedReplies: 11Last Post: 06-02-2014, 12:11 AM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Aluminium Tooling Sheet - Various sizes
By Fewco in forum Items For SaleReplies: 4Last Post: 16-01-2013, 04:27 PM
