Thread: pushing power of Steppers?
If the range is small, add 2 springs in tension, pulling up, to take some of the load. Set them pointing outward at 45deg or so, so that they give a gentle pull all the way through the range. Either do some maths, or use trial and error. Important thing is:
Springs do not go slack at top
Springs do not go so tight at the bottom that there is more load on the leadscrew than there would have been without them
This will also reduce self wind (rhymes with mind not thinned!)
Set it so that without the leadscrew connected the load hangs about halfway down. Then add the leadscrew and motor. This is a bit like an industrial assist, sometimes called zero g assist. Some Z axis routers (mechmate??) use this idea.
Drives without steppers
By Wobblycogs in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 27-03-2014, 01:07 PM -
motor power and chinese spindles power HELP
By DigiSoft in forum Spindles & Drive MotorsReplies: 5Last Post: 17-09-2013, 12:17 AM -
Cheapest CNC steppers I've ever seen!
By D.C. in forum Marketplace DiscussionReplies: 5Last Post: 02-02-2013, 11:22 AM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
Emco 5PC steppers
By Ian Hart in forum Stepper & Servo MotorsReplies: 17Last Post: 26-02-2010, 02:47 PM
