Perhaps you aren't understanding the big advantages of the Clarkson collet.
It doesn't rely on pinching the tool shank to hold it vertically, only to hold it concentric at the bottom of the collet.
The tool extension and tool concentricity at the top is set by the collet centre entering the centre pip on the back of the tool. You can change tool without adjusting the Z.
Because the tool extension is set there is no way on God's green earth it can slip vertically in the collet.
If there is runout then that usually means someone didn't understand how the collet operated, inserted a grub screw and tried to pinch an unthreaded tool thereby nadgering the chuck centre which aligns the tool top. The collet is a loose fit in the chuck so you need to preserve the centre.
To set a Clarkson you do the nose up gently, screw the tool in until it hits the pip, back the nose off a quarter turn, screw the tool in tight. Tighten the nose. No huge spanners required, you aren't gripping the tool, merely supporting it.
Now't wrong with a Clarkson except you need tooling designed for it. A good choice for facing with an end mill.Last edited by Robin Hewitt; 06-09-2010 at 12:36 PM. Reason: Didn't explain it very well
FOR SALE: 3 sets of 4 xl pulleys and a plasma machine torch
By nobby in forum Items For SaleReplies: 0Last Post: 20-05-2014, 07:33 PM -
Clamping sets / Step blocks and clamps
By dudz in forum Marketplace DiscussionReplies: 3Last Post: 10-06-2013, 06:03 AM -
FOR SALE: For Sale, Chinese 1.5kw spindle (er11 collet) with matching VFD! with 4 & 6mm collet
By jcb121 in forum Items For SaleReplies: 1Last Post: 29-01-2013, 11:05 AM -
WANTED: collet chuck
By Miniman in forum Items WantedReplies: 2Last Post: 13-12-2012, 05:26 PM -
Stupid question I know... but - What size is my Spindle Collet ?
By Fivetide in forum Milling Machines, Builds & ConversionsReplies: 17Last Post: 25-11-2012, 03:34 PM
