Thread: Lost my balls!!!
19-08-2010 #21
Thanks for that.
Ideally I'd like to try a drop in replacement; but if I can't find a suitable one then I might be in touch :)
The ball screw is 7.80mm OD, 2.54 pitch.
Cheers,
Dan
19-08-2010 #22
are you sure the pitch is right, they're normally metric. My guess would be 2.5mm.
19-08-2010 #23
I'll double check tonight; I measured ~2.5mm over 1 thread so I measued 5 threads over the fine groove on the OD.
12.80mm over 5 threads.
You don't know of anywhere that would sell drop in replacements would you? (apart from Boxford at this point)
Ta,
Dan
19-08-2010 #24
you can get the larger ballnuts, but not the smaller ones. Saying that boxfords price isn't too bad.
19-08-2010 #25
OK, replacement ball screw and ball nut for the x-axis is £204.95 inc VAT + delivery.
Does anyone have a cheaper drop in solution? Or am I gonna have ta sell my shoes to buy this replacment part?
I couldn't find a suitable sized replacement on MotionControlProducts. :cry:
19-08-2010 #26
Cant you just remake the recirculation tube? as far as I know it only feeds the balls back to the start, any preload is normally provided by the ball size, I would have thougth a small length of brass or copper pipe that you can get from model shops would be at least worth a go before you shell out all that money :o)
I have a similar looking one at at home but I'm not sure its 2.5mm pitch. I'll have a look when I get home.
19-08-2010 #27
you could replace the whole thing with an aftermarket ballscrew, but you'd end up with a flanged ballnut. Not a real problem but you'd loose a bit of travel.
Belts or Balls getting me Screwed up! Help I need advice Please.
By longy in forum Belt Drive, Pulleys & TimingReplies: 15Last Post: 15-04-2014, 02:46 PM -
ballnut - balls back in via the side cover and using less balls than original
By dsc in forum Lead Screws, Nuts & SupportsReplies: 9Last Post: 16-11-2013, 04:27 PM -
How to get the balls back in a ballnut?
By Shinobiwan in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 24-03-2013, 04:35 PM -
Balls, balls and balls
By Swarfing in forum Marketplace DiscussionReplies: 15Last Post: 21-03-2013, 08:45 PM -
X2 change balls crews or not?
By Oldie45 in forum Sieg Milling MachinesReplies: 7Last Post: 17-08-2011, 07:55 PM
