Thread: Positive backlash???
18-08-2010 #1
Hi All..
Finally getting down to some fine tweaking... In trying to measure any slop, and I am sure I have some as my X and Y are chain driven, I have been machining some slots 100mm long..
First I move the X axis in the +ve direction, then machine a slot also in the +ve direction.. Reckon there should be no backlash at this point.. Then I move a few mm across the y axis and machine a slot in the -ve direction of the X axis.. This should, by my reckoning, then show up any backlash and I was expecting the second slot to be shorter...
But no..! It was 0.2mm longer... Have repeated this several times with the same result..
And, as always, when I get to scratching my head too much, I pop here to see what silliness you guys can point out that I am doing..
Steve..
18-08-2010 #2
Hi Steve
what happens if you zero a DTI next to the machine before it cuts the first slot, then send it away in +ve X to cut the slot, then just come back to the start position again (i.e. cut the slot twice with no Y movement)?
what happens if you do this without cutting (just jogging away and back again) to a fixed DTI?
Lost steps? Binding axes?
18-08-2010 #3
Cogging maybe? A chain is moving slightly faster when a roller passes perpendicular to the sprocket axle.
18-08-2010 #4
Okidoki..
Things to look at.. Things to try... Will try/look at later this afternoon... Thanks guys!!
Steve
Micro lathe Zero backlash* conversion
By Jonathan in forum Lathes, Lathe Rebuilding & ConversionsReplies: 14Last Post: 22-09-2012, 10:56 PM -
Is this an example of what backlash can do?
By Minnican in forum Machine DiscussionReplies: 19Last Post: 06-03-2011, 08:59 PM -
backlash mack3
By h4ppy-chris in forum General DiscussionReplies: 9Last Post: 29-01-2011, 01:11 PM -
Sieg X3 backlash...
By Vikash in forum General DiscussionReplies: 0Last Post: 20-10-2010, 02:51 PM -
Sieg C3 backlash problem
By Cret in forum Milling Machines, Builds & ConversionsReplies: 10Last Post: 08-09-2009, 07:18 AM
