    Quote Originally Posted by CheekieMonkies View Post
    Have you got any pics of your pump
    I have the working drawing if that's any good, the pump is up at my shop.
    That's a 40mm impeller, (I just happenned to have some 40mm diam polyurethane)
    I drive it with a DC motor through a variable voltage regulator, that way I get to adjust the flow using a pot on the front of the machine. Works good :D
    Would be nice to see some pics if you get a chance Robin, will defo come back to this at some point.
    FWIW, a picture :D
    Now that looks KOOL !
  5. #15
    Maybe that's why it's called koolant? :D
  6. #16
    I draw everything with AutoCad, convert the milling to G code and overlay the .dxf file on the cut file. Then I can use the "Move to hole" feature which puts me on the hole nearest the mouse.
    Hi Robin,
    Can you share some more info on this process?
    Cheers.
  7. #17
    Quote Originally Posted by Hogout View Post
    It's home brewed software that pumps Gcode out to the parallel port as steps.
    It is a bit simple minded when it comes to arcs and you have to boot DOS so it has full control of the timer interrupt, but you are welcome to a copy if insane enough
    Robin
  8. #18
    Forget centre drills, they are a throwback to earlier days and were designed for putting in the support holes for centres on lathes, hence the name.
    No commercial CNC shop would dream of using centre drills today, instead using what are called NC spotting drills.
    These are very stiff short fluted drills that will start a hole off without wander and not break like the flimsy centre drills.
    Nearly the same results can be obtained using a good quality stub drill.
    John S.
  9. #19
    And avoid "UK Drills" on ebay.
    I bought £30 worth of cheap Jobbers bits, the first two I tried broke almost instantaneously, the rest followed them quickly in to the bin
    Hi Kip
    My Z axis is delayed. First I'm remaking my standoffs for the milling table. The previous set was too clever, interchangeable bolt holes in different sizes. I soon lost precision.
    This time I'm making 20 in 5 different threads, all cut from the same 3/4" thick steel bar and all 3/4" thick
    Robin
  10. #20
    Forget centre drills, they are a throwback to earlier days...... instead using what are called NC spotting drills.
    John,
    I have looked at the webpages of the usual suspects but none mention 'spotting drills' only centre drills. Do you have a source?
    Cheers.
  1. End mills / Drill bits for aluminium
    By ivars211 in forum Tool & Tooling Technology
    Last Post: 10-04-2014, 08:01 PM
  2. Step drill bits (where to get) ?
    By Gytis in forum Marketplace Discussion
    Last Post: 07-08-2013, 12:04 AM
  3. FOR SALE: dormer jobber A100 drill bits
    Last Post: 19-03-2012, 12:39 PM
  4. best drill bits
    By oadamo in forum Tool & Tooling Technology
    Last Post: 01-01-2011, 11:25 PM
  5. Split Point Drill Bits
    By Lee Roberts in forum Tool & Tooling Technology
    Last Post: 10-07-2008, 02:06 AM
