Thread: Center Drill Bits
22-06-2008 #1
Hi, i have recently recived some center drill bits as recomended by another member, i know what they are and how to use them.
I was just wondering if anyone had any advice or Tip when using them, i have been using them to make nema 23 motor mounts for my cnc machine:
22-06-2008 #2
Sorry kip i hit the wrong button, kips posts are below:
Be careful when using small ones on hardened steel...they break!
And use a scriber rather than a marker pen as it's better for accuracy and never rely on a piece of metal being "square" when marking out.... :D
22-06-2008 #3
Yes it did take me a few go's to get the holes right, i managed to get the holes close enuff that i could then file out a small amount so my screws would line up with the motors.
Now i have a template i just use that to make/mark out new plates and so on:
There are some really naff centre drills around, regular PITA when they snap off. I got some cheap, centred 2 holes then lobbed the lot straight in the bin.
Caveat emptor, I've gone back to Plan A, don't use anything but Dormer :D
23-06-2008 #5
23-06-2008 #6
You really need CNC it makes it so easy and everything lines up just perfect. No more swapping centre drill then bit then countersink/bore on every hole :D
I draw everything with AutoCad, convert the milling to G code and overlay the .dxf file on the cut file. Then I can use the "Move to hole" feature which puts me on the hole nearest the mouse.
23-06-2008 #8
:) now i can mount my motors, my machine can move/work, guess what i will e making with my machine once its up and running :D
24-06-2008 #10
Yea i was thinking i'm gonna need to keep things cool if i'm doing ali cuts ? i was thinking of having a vac to clear the "chips" and my compressor blowing to keep the cutter cool ?
Have you got any pics of your pump?, this cnc stuff is leading me into so many "new area's" of making things so on, i love it i wish i had tuned in at school and gone down this path for a career.
Cheers,
End mills / Drill bits for aluminium
By ivars211 in forum Tool & Tooling TechnologyReplies: 7Last Post: 10-04-2014, 08:01 PM -
Step drill bits (where to get) ?
By Gytis in forum Marketplace DiscussionReplies: 10Last Post: 07-08-2013, 12:04 AM -
FOR SALE: dormer jobber A100 drill bits
By Web Goblin in forum Items For SaleReplies: 1Last Post: 19-03-2012, 12:39 PM -
best drill bits
By oadamo in forum Tool & Tooling TechnologyReplies: 4Last Post: 01-01-2011, 11:25 PM -
Split Point Drill Bits
By Lee Roberts in forum Tool & Tooling TechnologyReplies: 0Last Post: 10-07-2008, 02:06 AM
