21-08-2010 #12
Forgive my stupidity, by why do you need all that z-movement for a wind turbine blade? If you're thinking of cutting them vertically 'on the hub' so to speak I think you run the risk of, as a minimum, the blade deflecting, or worse snapping off... anything that high a length to width ratio probably needs milling horizontally and adequately supported... or have i got the wrong end of the stick (or should that be blade?) :lol:
Ross77's Z Axis Design
By Jonathan in forum Open Source Designs & PlansReplies: 1Last Post: 20-05-2013, 06:09 PM -
Z-Axis design and advice
By Mad Professor in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 06-04-2013, 11:00 AM -
Help wanted design laser X-axis
By gavztheouch in forum Open Source Designs & PlansReplies: 12Last Post: 11-03-2013, 07:00 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM -
Y axis design
By GeorgeD in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 15-07-2010, 03:04 AM
