22-08-2010 #30
Maybe I've got to the stage where I should just try it and see and just accept that I may have to compromise on cutting depths to reduce the cutting forces.
That's a good point. Looking at the drawing for the bearing blocks if the force is in the 'worst' direction with the supported rails then it's only supported on 2 of the little ball bearings compared to 4 on the unsupported ones.
With this in mind maybe I should mount the supported rails 'back to back' on the Z-axis aswell as the Y.
Second hand: true, you never know.
Indeed
I think I'll go for the 600 and 900 supported rails for £155. That's already much more than I was intending to spend and a much better design.
Has anyone here bought from that seller / can confirm that they're good?
Ross77's Z Axis Design
By Jonathan in forum Open Source Designs & PlansReplies: 1Last Post: 20-05-2013, 06:09 PM -
Z-Axis design and advice
By Mad Professor in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 06-04-2013, 11:00 AM -
Help wanted design laser X-axis
By gavztheouch in forum Open Source Designs & PlansReplies: 12Last Post: 11-03-2013, 07:00 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM -
Y axis design
By GeorgeD in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 15-07-2010, 03:04 AM
