20-08-2010 #9
Luckily the microwave survived - some pretty impressive flames though!
So do you think the price of those rails implies that they are probably not up to much?
16mm supported rail and bearings works out at £93.60+VAT from Zapp compared with £45+VAT for the 20mm unsupported.
The open bearing pillow blocks are only a few £ more, so that's fine. I hadn't thought of stress in the rails. If it does work I reckon it's worth the effort to save about £40!
I'm currently dimensioning the drawing - I'll post it as soon as I'm done. But basically the 4 bearings are currently spaced as a square, 100mm between centres - hence the rails are also 100mm apart. The rails are 600mm long (the above prices are for 700mm just to be safe) which leaves a nice 400mm or so travel.
Thanks for the help so far - much appreciated!
Ross77's Z Axis Design
By Jonathan in forum Open Source Designs & PlansReplies: 1Last Post: 20-05-2013, 06:09 PM -
Z-Axis design and advice
By Mad Professor in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 06-04-2013, 11:00 AM -
Help wanted design laser X-axis
By gavztheouch in forum Open Source Designs & PlansReplies: 12Last Post: 11-03-2013, 07:00 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM -
Y axis design
By GeorgeD in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 15-07-2010, 03:04 AM
